Noise when slamming the breaks
Old Dec 8, 2008 | 10:26 AM
detroit pistins's Avatar
Hi,
when i hit the breaks hard (as in full force on the pedal) at moderate speeds (say less than 40-50 mph) I hear a squealing noise from the back (possibily the passenger brakes) any ideas what that is? this only occurs when u slamm the breaks and no noise at all if ur breaking normaly.
Thanks,
Old Dec 9, 2008 | 09:11 AM
vitamin ek2's Avatar
did you put a slotted rotors??? coz i have the same problem.
Old Dec 9, 2008 | 09:53 AM
ryanlao's Avatar
new rotors, lines, fluid or pads? did you do/change anything recently ?
Old Dec 9, 2008 | 10:01 AM
mifesto's Avatar
with such little background info your giving, its difficult for anyone to help you.
Old Dec 9, 2008 | 10:06 AM
whitedsm97's Avatar
i have slotted rotors in the front and when abs kicks in, sounds like a grinding noise.
Old Dec 9, 2008 | 10:08 AM
Smike's Avatar
Agreed.
And to those with slotted rotors - they should not be grinding.
OP - its normal of the OEM Brembo pads. There are shims on the brakes.
Get the red brake lube and coat the backing plate and shim. But if you only have this problem at 100% effort braking - find something else to worry about.
Old Dec 9, 2008 | 10:10 AM
JordanS4's Avatar
Brakes Brakes Brakes Its Spelled Brakes!!!!!!!!
Old Dec 9, 2008 | 10:14 AM
hotrod2448's Avatar
This. You beat me to it.
Old Dec 9, 2008 | 10:15 AM
evane's Avatar
come on! give the dude a brake!!!
Old Dec 9, 2008 | 10:32 AM
mifesto's Avatar
i love noobs coming on and expecting people to spoon feed them the answer. its like walking into the doctors office and stating, "doc, im in pain. what should i do?" he'll give you the "you an idiot" look.
tell us background info like....
1.did you change the pads(or any other brake parts) recently and getting squeals?
2.did you ever bother to check how much meat your pads have?
etc etc
Old Dec 9, 2008 | 07:30 PM
etc etc
if i have changed those parts then i would have definitly mentioned something about them and not kept it a secret.
guys,
No i haven't changed anything recently on the car and yes it appears on a 100% brake force.a friend of mine suggested that i take off all the junk in the trunk and try it again to see if maybe something in there is squealing out of place when breakking hard.
thanks and i will keep u guys posted.
Old Dec 9, 2008 | 08:14 PM
Smike's Avatar
And again - its braking not breaking. One stops cars, one needs fixing.
But seeing you cannot spell your own screen name...detroit pistons - being a Detroit native, that grinds my gears.
Old Dec 9, 2008 | 08:31 PM
perhaps pistons was already taken, have u thought about thought?
thanks for paying more attention to spelling than the actual technical issue here.
Old Dec 9, 2008 | 08:35 PM
mifesto's Avatar
AGAIN, you give us zero information on your car... JESUS CHRIST LOL. its very frustrating..... ok i'll spoon feed you.
1.what year is your evo? mileage?
2.are you the first owner?
3.if you arent the first owner, did you bother to check how much pads are left in the back?
Old Dec 9, 2008 | 08:42 PM
fryedchikin's Avatar
Originally Posted by detroit pistins
Hi,
Thanks,
Maybe it's your trunk monkey squealing as his head is being slammed against the rear passenger seats
