How to disable P0710 ?
Old Jan 23, 2009 | 07:14 PM
Darwinn's Avatar
Any chance to disable P0710 through periphery bit? I have switched from 6speed EDM (88840017) with Transmission fluid temperature sensor to 5speed without it. I dont want to keep sensor connected to ecu if possible.
Also same with rear o2 sensor. Maybe someone found how to completely disable P0141 check through bits..
Old Feb 5, 2009 | 01:11 PM
kkarim's Avatar
I am having the same problem... Any help would be appreciated.
Can the ecu be fooled by putting a resistor or some circuit instead of the sensor?
Old Mar 21, 2009 | 07:11 AM
kkarim's Avatar
put a resistor between 75 ohm and 135 kohm instead of the sensor.
it worked for me.
Rico8638
Jul 13, 2019 10:29 PM
Rico8638
May 19, 2017 03:48 AM
wantanevo2
Aug 19, 2009 05:06 PM
Colt4g63
Feb 10, 2009 11:31 PM
black E
Feb 7, 2009 03:26 AM
