ok so i need help quick
Old Feb 27, 2009 | 07:26 AM
goofygrin's Avatar
Oh and regarding your ASC codes... from the service manual:
DTC SET CONDITIONS
This diagnostic trouble code is set when the output decrease request is rejected by the engine control module.
PROBABLE CAUSES
•Wrong coding
•Engine ECU malfunction
•ASC-ECU malfunction
•External noise interference
STEP 1. Using scan tool MB991958, diagnose the CAN bus lines.
Q:Is the check result normal?
YES :
Go to Step 3.
NO :
Repair the CAN bus lines. (Refer to GROUP 54C − Troubleshooting P.54C-14.) After repairing the CAN bus line, go to Step 2.
STEP 2. DTC recheck after repairing the CAN bus line
Q:Is DTC C121C set?
YES :
Go to Step 3.
NO :
The procedure is complete.
STEP 3. M.U.T.-III other system diagnostic trouble code
Using scan tool MB991958, check if a diagnostic trouble code is set in the engine control module. (Refer to GROUP 13A − Troubleshooting P.13A-44.)
Q:Is any DTC set?
YES :
Troubleshoot the diagnostic trouble code of engine control module. (Refer to GROUP 13A − Troubleshooting P.13A-44.)
NO :
Go to Step 4.
STEP 4. Scan tool service data
Check the following service data. (Refer to P.35C-255.)
•Item 68: Allow ESP torque request
YES :
Go to Step 5.
NO :
Replace the engine control module. (Refer to GROUP 13A − Engine Control Module P.13A-920.) Then go to Step 5.
STEP 5. Check whether the DTC is reset.
Q:Is DTC C121C set?
YES :
Replace the hydraulic unit (incorporates in ASC-ECU).(Refer to P.35C-272.) Then go to Step 6.
NO :
Intermittent malfunction. (Refer to GROUP 00 − How to Cope with Intermittent Malfunction P.00-15.)
STEP 6. Check whether the DTC is reset.
Q:Is DTC C121C set?
YES :
Return to Step 1.
NO :
Old Feb 27, 2009 | 03:04 PM
SOEuro's Avatar
Thanks for the help Goofy Grin,
the tune has the mivec fully advance,maybe that is the culprit
Old Feb 27, 2009 | 05:23 PM
gunzo's Avatar
Originally Posted by SOEuro
really,i was under the impression that PSI was all the same no matter what turbo,but bigger turbos flow greater CFMs...
and you are right about the MAP and MAF...im thinking that is the problem,but i am not fimiliar with ECUtek...can this be tuned out???
So is everyone else .. the higher CFM just comes from having bigger flow area ..
Utilising stock components with a bigger wheel doesn't gain you CFM because the flow area remains the same (ie the same compressor housing, IC piping etcetc)
that also meaning on stock turbo .. if you change your IC piping, IC etc .. you effectively change the CFM too at the same psi
If you go with a GT30/35 etc .. then you're running bigger housing affording more flow area .. yes .. your CFM increases with the same PSI ..
Finally .. your question .. YES .. if the ECUtek operator is familiar with the use of these tables ..
Old Feb 27, 2009 | 06:37 PM
PVD04's Avatar
Originally Posted by chdb2005
I’m disappointed with you guys don’t give advice if you’re not going to give good advice. first the turbo won’t cause a problem if you’re running stock boost. The ecu doesn’t give a **** what turbo you install it’s not going to magically crap out even if you install a gt35 xxlbs is xxlbs. Turbos are categorized by boost potential and efficiency (just so you know). By installing the red and running stock boost the only thing that could have changed is spool time which the ecu can compensate for perfectly with no problems. If you reach boost sooner than the ecu will add fuel and pull timing sooner vice versa. It's when you start adding boost is where you run into problem either by running the ecu out of it maps or by maxing out sensors which ever happens first. When it comes to your cams it’s a whole new story here’s the thing by getting bigger cams you change V.E. (volumetric efficiency, theoretical percentage of air entering the engine by the max theoretical amount of air that can enter the engine) this is more of a problem on map based system since its base off a fixed V.E. map and cant compensate for changes in V.E. but since the evo is also maf based and can also measure air flow it can compensate for your cams up to an extent before the sensor maxes out. Error codes 9 times out of 10 doesn’t just mean it’s the sensor its self usually it’s a code meaning something in the entire circuit is bad It can be bad power, ground, signal, or sensor so no more wasting money on parts if you’re not sure what the problem is okay, lol. I’ll tell you how to test your maf sensor I believe the evo runs MAF/IAT you can tell by the amount of wires MAF uses just three MAF/IAT Usually runs five two powers two signals and a common ground but I’ve seen different variations, I believe the evo run a five wire so make sure your testing the maf not the IAT. To start unplug the sensor using a DVOM (digital volt ohm meter) measure continuity to ground on the plug (harness side) around .2 ohm is okay the higher the number the worse it is start worrying when it above .6 ohms to much resistance will give you a bad “signal” reading to the ecu. You can check resistance across the maf by measuring between the signal and ground, and the power and ground on the sensor make sure its unplugged this is a must (cross reference the readings between the two maf sensors because I can’t tell you what the manufacture recommendations are) next plug the sensor in start the car. Test the voltage going into the sensor (this is called you reference voltage) I believe the evo runs a 5 volt reference just to make sure check it at the map sensor they use the same voltage if it’s a five volt reference then the ref. if it a 5 vlot ref. sytem the maf ref. should read 5volts or close if not i can also cause a bad signal as well. last check the signal voltage, car still running while idling the voltage will be very low blip the throttle the voltage should go up in relation to the throttle if you steadily give more and more throttle the voltage will climb steadily but usually tends to taper down some if you give it a lot of throttle and hold it the voltage will jump a lot but usually drop when you hold it. If your sensor maxes usually around 4.5volts with a little variation on the 4.5volts but you still have plenty of throttle left then it’s the cams. You can fix these problems with a little know how if you need help on the diagnosis or fixing the problem let me know I’ll be glad to help you out.
First, paragraphs are your friend. Second, the first part of your post is completely wrong. Increasing engine VE does result in more airflow at the same boost pressures. Putting on a larger turbo increases VE.
OP: You have drastically changed the VE of your engine by replacing the cams and the turbo. You are flowing more air at every boost level which is putting the car into limp mode. From what I've read of the X ECU, it has limits for airflow based upon boost pressure, TPS, and RPM. This is why you are going into limp mode even with light throttle. I would not be overly concerned as a new tune should resolve your problems.
Old Feb 27, 2009 | 06:52 PM
PR_Mivec's Avatar
Originally Posted by goofygrin
If the tune adjusted the mivec (which most do), then you can be doing all sorts of weird things with the cams.
I'd get retuned and then see what happens.
From Gunzo:
https://www.evolutionm.net/forums/6475663-post12.html
Your tune is likely right on the bleeding edge. Changing the cams likely pushed you over the edge... if you have a MBC, back it way down and see if that helps.
P0102
Mass airflow circuit low input
P1235
Mass airflow sensor plausibility
P1238
Mass airflow sensor plausibility (torque monitor)
according to my evo x service manual..... in fact.. let me just post the whole table...
P0011
Intake variable valve timing system target error
P0012
Camshaft position- timing over-retarded
P0014
Exhaust variable valve timing system target error
P0016
Crankshaft/camshaft (intake) position sensor phase problem
P0017
Crankshaft/camshaft (exhaust) position sensor phase problem
P0031
Heated oxygen sensor (front) heater circuit low
P0032
Heated oxygen sensor (front) heater circuit high
P0037
Heated oxygen sensor (rear) heater circuit low
P0038
Heated oxygen sensor (rear) heater circuit high
P0069
Abnormal correlation between manifold absolute pressure sensor and barometric pressure sensor
P0096
Intake air temperature circuit range/performance problem (sensor 2)
P0097
Intake air temperature circuit low input (sensor 2)
P0098
Intake air temperature circuit high input (sensor 2)
P0101
Mass airflow circuit range/performance problem
P0102
P0103
Mass airflow circuit high input
P0106
Manifold absolute pressure circuit range/performance problem
P0107
Manifold absolute pressure circuit low input
P0108
Manifold absolute pressure circuit high input
P0111
Intake air temperature circuit range/performance problem (sensor 1)
P0112
Intake air temperature circuit low input (sensor 1)
P0113
Intake air temperature circuit high input (sensor 1)
P0116
Engine coolant temperature circuit range/performance problem
P0117
Engine coolant temperature circuit low input
P0118
Engine coolant temperature circuit high input
P0122
Throttle position sensor (main) circuit low input
ON-BOARD DIAGNOSTICS
TSB Revision
13A-54 MULTIPORT FUEL SYSTEM (MFI)
P0123
Throttle position sensor (main) circuit high input
P0125
Insufficient coolant temperature for closed loop fuel control
P0128
Coolant thermostat (coolant temperature below thermostat regulating temperature)
P0131
Heated oxygen sensor (front) circuit low voltage
P0132
Heated oxygen sensor (front) circuit high voltage
P0133
Heated oxygen sensor (front) circuit slow response
P0134
Heated oxygen sensor (front) circuit no activity detected
P0137
Heated oxygen sensor (rear) circuit low voltage
P0138
Heated oxygen sensor (rear) circuit high voltage
P0139
Heated oxygen sensor (rear) circuit slow response
P0140
Heated oxygen sensor (rear) circuit no activity detected
P0171
System too lean
P0172
System too rich
P0181
Fuel tank temperature sensor circuit range/performance
P0182
Fuel tank temperature sensor circuit low input
P0183
Fuel tank temperature sensor circuit high input
P0201
Injector circuit-cylinder 1
P0202
Injector circuit-cylinder 2
P0203
Injector circuit-cylinder 3
P0204
Injector circuit-cylinder 4
P0222
Throttle position sensor (sub) circuit low input
P0223
Throttle position sensor (sub) circuit high input
P0234
Turbocharger wastegate system malfunction
P0243
Turbocharger wastegate solenoid 1 circuit
P0247
Turbocharger wastegate solenoid 2 circuit
P0300
Random/multiple cylinder misfire detected
P0301
Cylinder 1 misfire detected
P0302
Cylinder 2 misfire detected
P0303
Cylinder 3 misfire detected
P0304
Cylinder 4 misfire detected
P0327
Knock sensor circuit low
P0328
Knock sensor circuit high
P0335
Crankshaft position sensor circuit
P0340
Intake camshaft position sensor circuit
P0365
Exhaust camshaft position sensor circuit
P0420
Warm up catalyst efficiency below threshold
DTC*1 DIAGNOSTIC ITEM MIL*2 ITEM
TSB Revision
MULTIPORT FUEL SYSTEM (MFI) 13A-55
P0441
Evaporative emission control system incorrect purge flow
P0442
Evaporative emission control system leak detected (small leak)
P0443
Evaporative emission purge solenoid circuit
P0446
Evaporative emission ventilation solenoid circuit
P0450
Fuel tank differential pressure sensor malfunction
P0451
Fuel tank differential pressure circuit range/performance problem
P0452
Fuel tank differential pressure circuit low input
P0453
Fuel tank differential pressure circuit high input
P0455
Evaporative emission control system leak detected (gross leak)
P0456
Evaporative emission control system leak detected (very small leak)
P0461
Fuel level sensor circuit range/performance
P0462
Fuel level sensor circuit low input
P0463
Fuel level sensor circuit high input
P0500
Vehicle speed signal malfunction
P0506
Idle control system RPM lower than expected
P0507
Idle control system RPM higher than expected
P0513
Immobilizer malfunction
P0551
Power steering pressure switch circuit range/performance
P0554
Power steering pressure switch circuit intermittent
P0603
EEPROM malfunction
P0606
Engine control module main processor malfunction
P0622
Generator FR terminal circuit malfunction
P0630
Vehicle Identification Number (VIN) malfunction
P0638
Throttle actuator control motor circuit range/performance
P0642
Throttle position sensor power supply
P0657
Throttle actuator control motor relay circuit malfunction
P0830
Clutch pedal position switch circuit range/performance
P1021
Intake engine oil control valve circuit
P1025
Exhaust engine oil control valve circuit
P1231
Active stability control plausibility
P1232
Fail safe system
P1233
Throttle position sensor (main) plausibility
P1234
Throttle position sensor (sub) plausibility
P1235
P1236
A/D converter
P1237
Accelerator pedal position sensor plausibility
P1238
TSB Revision
13A-56 MULTIPORT FUEL SYSTEM (MFI)
P1239
Engine RPM plausibility
P1240
Ignition angle
P1241
Torque monitor
P1242
Fail safe control monitor
P1243
Inquiry/response error
P1244
RAM test for all area
P1245
Cycle RAM test (engine)
P1247
TC-SST plausibility <TC-SST>
P1320
Ignition timing retard insufficient
P1506
Idle control system RPM lower than expected at low temperature
P1507
Idle control system RPM higher than expected at low temperature
P1590
TCM to ECM communication error in torque reduction request <TC-SST>
P1603
Battery backup circuit malfunction
P1676
Variant coding
P2066
Fuel level sensor (sub) circuit range/performance
P2100
Throttle actuator control motor circuit (open)
P2101
Throttle actuator control motor magneto malfunction
P2122
Accelerator pedal position sensor (main) circuit low input
P2123
Accelerator pedal position sensor (main) circuit high input
P2127
Accelerator pedal position sensor (sub) circuit low input
P2128
Accelerator pedal position sensor (sub) circuit high input
P2135
Throttle position sensor (main and sub) range/performance problem
P2138
Accelerator pedal position sensor (main and sub) range/performance problem
P2195
Heated oxygen sensor (front) inactive
P2228
Barometric pressure circuit low input
P2229
Barometric pressure circuit high input
P2252
Heated oxygen sensor offset circuit low voltage
P2253
Heated oxygen sensor offset circuit high voltage
P2263
Intake charge system malfunction
U0001
Bus off
U0101
TC-SST-ECU time-out <TC-SST>
U0121
ASC-ECU time-out
U0141
ETACS-ECU time-out
U0167
Immobilizer communication error
U1180
Combination meter time-out
im experimenting a mechanical way to eliminate limp mode, it can be tunned on top of it, so far the only downside it leans the hell out of the car, so nothing a tune can fix....
if you know me you should know my fixes are as ghetto as can be..... ill post results later in the week since im developing it w/ my tunner and my mechanic
Old Feb 28, 2009 | 02:08 AM
chdb2005's Avatar
wow you need to go back and read it agian because thats not even close to what i said.
once again people boost is boost if the turbo is bigger and you have a higher cfm doesn't mean when at ten pounds you'll have more air in the cylinder than a smaller turbo at ten pounds. the difference is how fast your car is going to reach ten lbs per given shaft speed. efficiency
Old Feb 28, 2009 | 07:53 AM
PVD04's Avatar
I read what you said correctly, and it is still wrong. Boost is boost, but we're talking about mass air flow. The engine is a pump with pressure on the intake side and pressure on the exhaust side. With a larger turbo you have less back-pressure on the exhaust side resulting in less residual exhaust gas in the cylinder. This means more clean air is ingested per revolution and more airflow is read by the MAS at the exact same inlet boost pressure.
tscompusa
Nov 16, 2017 05:44 AM
TreatsIX
For Sale - Cars For Sale
Mar 21, 2016 04:02 PM
xexitenglishx
25
Jan 16, 2011 09:00 PM
hennessey01
Mar 27, 2010 11:00 PM
dxbevo9
18
Jun 18, 2009 04:07 AM
