Found - Short Term Fuel Trim maps
Old May 7, 2009 | 06:56 PM
  #31
Appauldd's Avatar
Kind of related....
0.1953125*x-25
This gives extremely accurate results for the the trims. No more .1008 with this.
Old May 8, 2009 | 06:06 AM
  #32
Mattjin's Avatar
96940011 - the addresses are 2d90 and 2d9e. Temp Scale address is 5e5e.
90550001 - 389e & 38ac. Temp is 575c.
And for us Aussies...
88580015 - 30cc & 30da. Temp is 71ca.
Old May 8, 2009 | 07:56 AM
  #33
fostytou's Avatar
EvoM Community Team
Originally Posted by lan_evo_mr9
I put in the scalings and it still is coming up with only half the graph- here's how I have it
<!-- *** SCALINGS *** -->
<scaling name="O2 Trim" units="%" toexpr="(x-128)/5" frexpr="(x*5)+128" format="%.1f" min="-25.6" max="25.4" inc="0.2" storagetype="uint8" endian="big"/>
<scaling name="AFR" units="AFR" toexpr="14.7*128/x" frexpr="14.7*128/x" format="%.1f" min="5" max="30" inc="0.1" storagetype="uint8" endian="big"/>
<scaling name="AFR16" units="AFR" toexpr="14.7*128/x" frexpr="14.7*128/x" format="%.1f" min="5" max="30" inc="0.1" storagetype="uint16" endian="big"/>
If I add remove this definition from the base file it doesn't matter how the table comes up in ecuflash. What am I doing wrong? I've never had a problem with patching. I've got 5.10, and a few other patches on my rom.
I'm naughty, I don't follow proceadure/sectioning in my personal XML. I just added the O2 Trim scaling and the 2 definitions into my _mods xml.
If the right column is the only one not showing up, your scaling or address problem is with the O2 Trim scaling. Unfortunately your scaling as-posted looks OK.
Old May 9, 2009 | 05:42 PM
  #34
Danieln's Avatar
Hi Mattjin
Do you please add also for 88840017 and 88840016 if you have them?
I will appreciate so much
Thanks
Old May 9, 2009 | 06:49 PM
  #35
lan_evo_mr9's Avatar
got it to work- had to put the scaling into my rom instead of my base file for some reason. I'm running dual maps, so how would I make these new tables effective to me?
Old May 9, 2009 | 08:40 PM
  #36
Mattjin's Avatar
Dont worry, my own xml files are a complete wasteland but mostly because there have been so many maps mislabelled or previously undefined. I will leave the cleaning up until the work is done.
Has anyone found if there is an easy way to add new categories to ecuflash besides the default list? I know to simply change it in the xml, but when finding new maps it slows things down.
mrfred
Aug 1, 2022 06:05 AM
Dynotech Tuning
Sep 20, 2016 01:30 PM
mrfred
Oct 2, 2015 12:41 AM
mrfred
Dec 21, 2014 10:13 AM
Mattjin
Oct 11, 2009 03:11 AM
