What's your Stock Turbo HP/TQ?
Old Jul 19, 2009 | 10:39 PM
BLKCarbonEVO's Avatar
Originally Posted by 90GSXDan
Dont have my dyno sheet, but its an 06 IX, stock turbo (unported), stock exhaust mani(unported), buschur ported intake mani + tb, drop-in piston motor, cosworth m2's with gsx beehives, ets 3.5" intercooler kit, AEM Meth kit, AEM EMS, 32psi - 429awhp/480awtq
Dan
Sick numbers! You running stock rods?
Old Jul 20, 2009 | 12:29 AM
Fast_Freddie's Avatar
Veteran: Navy
^ Doubtful Mikey, usually when people do drop ins they do both pistons and rods...
Old Jul 20, 2009 | 05:14 AM
matt55's Avatar
TQ is a little low , tuned on the road and the dynojet didnt load the car same down low .....
edit 93 pump
Attached Thumbnails What's your Stock Turbo HP/TQ?-dyno.jpg
Old Jul 20, 2009 | 05:45 AM
RyuEvoIX's Avatar
442whp 482wtq.
Old Jul 20, 2009 | 10:36 AM
Veteran: Navy
Heres mine... IX turbo compared to a VIII with 10.5 hotside...
Old Jul 20, 2009 | 11:11 AM
Man i need to figure out how to make the dynos fill the whole page Good gains Freddie. The IX turbo really held up top and spooled nice! Did Eric port that?
Old Jul 20, 2009 | 02:58 PM
EVOIXreno's Avatar
looked at your graph. Just a question is your AFR measured at the tail pipe( sniffer) or in the downpipe/testpipe... My AFR is a little rich for using such a big nozzle and I can really do much about it.
But AMAZNG gains in the mid range... the ~5psi of boost is helping alot... right now I am at 29psi.. I will be going to 34psi tonight!
Old Jul 20, 2009 | 03:08 PM
dmoevo's Avatar
here is mine...there is an overlay of a before and after with the shearer dump
~30psi
Old Jul 20, 2009 | 04:56 PM
JohnBradley's Avatar
He had them at both locations at that particular dyno. His onboard is the one we tuned off and the sniffer was tailpipe of course.
Old Jul 20, 2009 | 07:29 PM
Veteran: Navy
Yeah Eric ported it for me!
Old Jul 20, 2009 | 08:34 PM
Question answered... Thanks Aaron
Old Jul 20, 2009 | 08:35 PM
Evo2wIsh4's Avatar
Here is Mines on the stock 9 Turbo+ Meth 33psi
Old Jul 21, 2009 | 08:55 AM
Evo2wIsh4's Avatar
Nice Thread!
Old Jul 21, 2009 | 09:44 AM
SeanV's Avatar
Here mine on a stock Evo 9 turbo with a 50/50 ethanol/pump fuel mix (E50) on our crappy fuel we get in South Africa.
Mods on my Evo 8...
Stock Evo 9 turbo, BC 272 cams, Megan O2 housing, Tephra V7 mods/patches (ECU controlled boost with Greddy 3 port solenoid), Works down pipe, Snow Performance WI using the smallest jet - injecting water only. Custom SS 76mm decatted exhaust with Megan back box.
Forge 1,5 bar actuator, Stage 4 Competion clutch.
@2 bar boost = 29 PSI
269wkw = 360HP
550nm torque = 405 Ft lbs
Dyno run was done in Johannesburg, South Africa, which is 5,558 ft / 1,694 m above sea level.
Two vids of the dyno run...
1st run
http://www.youtube.com/watch?v=eF9QQl-T6Sc
2nd run
http://www.youtube.com/watch?v=sUzLD6LzJDc
Old Jul 21, 2009 | 10:09 AM
TTP Engineering's Avatar
Put those nanometers to the ground!
