EvoScan EvoX Datalogger now supports 2byte Boost/Load/IPW
for LC1Rear02 you gotta wire the lc1 analogue output into the D35 plug under the seat, itsthe bottom right connector or the yellow wire.
then just setup your LC1 with the right analogue settings and you cna log the LC1 via the ECU... no need for the serial cable...
Is it possible to find the request address for LC1RearO2 for ROMID 53040007?
Their usage is indicated in their names. For the Evo 8/9, load fuel is always the highest, and depending on the air temperature, and the other two can be as much as 15 lower than load fuel. For the Evo 8/9 community, everyone just logs load for fuel and recognizes that for ignition and MIVEC tuning, the actual load maybe slightly lower than the load that they logged. It would be good to see somone post up a plot for the Evo 10 to see is the loads vary in the same way.
I'm trying to log 5304007 with JDM 2008 xml. All work perfect except
1. Wrong formula for InVVT. It should be the same as for ExVVT Eval="(x-4096)*-0.01953".
2. LoadMIVEC don't work properly. It show something, but real load is 2-3x more. Tested using timing and mivec values.
Sorry for the double post but i think it is the right thread.
Hi all,
Please can you explain why i cannot get my aem uego to log through evoscan, what is weird is that it's working on hyper terminal? here is the error log:
Info: OpenPort 2.0 Found.
Info: OpenPort Firmware v1.07.259
Info: Battery 11,807V
Info: Initialize Vehicle ECU...
Info: Initializing CAN...
Info: CAN Connected...
Info: Connection successful...
Error: Object reference not set to an instance of an object.
at System.Windows.Forms.Control.MarshaledInvoke(Contr ol caller, Delegate method, Object[] args, Boolean synchronous)
at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
at #=qH7E777JbeJrjOu0kHLKN8Q98wfszgezClMV$M2PGzeY=.#= q1vj0lpDnMD4d_9YwRU5NPwySpukLfbVxNBTNI6snjNI=(Obje ct #=qwtDeWGdPkC36daAvQEXuzA==, #=qVj$jOrHYArnvB$OJMIYcOM$Pk6$hePTM0u2EoKqSopW1a4a TspxR6Dz_wKVSlwuJ #=qgG1vqHp4db0mQOrlqnLfeA==)
at #=q$$OQeW4kUpJYVxFyTXkRXG$BAuRXabx9nMWi2ih1wXo=.#= q8IoYZB_ghSq7TgoActyFjARG_0fBsESECeJ$0gGrfQ0=(Obje ct #=qxnXczwSEWJSwmXUTuAuvXg==, #=qVj$jOrHYArnvB$OJMIYcOM$Pk6$hePTM0u2EoKqSopW1a4a TspxR6Dz_wKVSlwuJ #=q_1Xk5vt6yXPPQ7CBz0$33g==)
at #=q$$OQeW4kUpJYVxFyTXkRXG$BAuRXabx9nMWi2ih1wXo=.#= qbb_IWhExjSwnrKcDsWcqTg==(Double& #=qBClifrCnW3XIMxS4sq_TMA==)
at #=q$$OQeW4kUpJYVxFyTXkRXG$BAuRXabx9nMWi2ih1wXo=.#= qFJn4mhLQUsnW9xKyzSgkag==()
Info: Datalogger Ended.
Hi all,
log a call at my helpdesk www.evoscan.org/helpdesk
i can't test the specific error until i get home but the only problem i consistently get with my aem wideband is that my laptop likes to change the com ports between 8-9 everytime i boot or plug in the usb adapter. it throws and error when i go to log and i have become acustom to knowing to change the com port. so EVOXSILVER if your using a serial->usb adapter ensure that the same has not happened to you. In my case it is an OS error
evo4mad, i've just opened a new ticket on your support desk.
newcomer81, yes you are right about the com port problem, my OP cable is on Com 3 and my prolific Serial/Usb on Com 2. What is weird is that everything works great until i check "external Wideband".
