Differences between EvoScan and Tactrix cable?
Old Aug 11, 2009 | 07:05 PM
  #61
bluelancer20028's Avatar
i can pull my rom with no problem but i can not put anything on ecu from ecuflash . ecuflash keeps giving like a error and i can hear the ecu click . so if anyone has any advice im open for suggestions
19:16:27.000] sending init sequence 1 (0003)
[19:16:28.031] got 0x05 response
[19:16:28.031] sending init sequence 2
[19:16:28.046] got 0x1B response
[19:16:28.046] sending init sequence 3
[19:16:28.421] entering bootloader
[19:16:28.437] sending kernel size (4420)
[19:16:28.453] sending kernel load address (0xFFFF7000)
[19:16:28.453] uploading kernel
[19:16:29.171] verifying kernel checksum response
[19:16:29.171] kernel valid
[19:16:29.390] kernel get version
[19:16:29.406] rkrv: preamble 1 error
[19:16:29.421] reading kernel comm buffer size
[19:16:29.625] reading kernel flash buffer size
[19:16:29.843] interface close
this is the log from ecuflash and i can log on evoscan fine just can not rewrite the ecu
Old Aug 12, 2009 | 12:07 AM
  #62
funks's Avatar
Did you get the right EVOSCAN cable? he has three versions
The OpenPort 1.3D (only useful for Datalogging)
The OpenPort 1.3R (only useful for Datalogging and Reprogramming the ECU if using EVOSCAN, not ECUFLASH as it doesn't have the necessary ECUFLASH serial number)
The OpenPort 1.3U (useful for Datalogging and Reprogramming with ECUFLASH, has the necessary ECUFLASH serial number)
Old Aug 12, 2009 | 05:57 PM
  #63
im not to sure how do i check. i bought it off here
Old Aug 13, 2009 | 09:32 PM
  #65
my cable has usb connector, large black connector, and smaller white connector as before everything works but reflashing
Old Aug 14, 2009 | 04:32 AM
  #66
evo4mad's Avatar
Yes the one I sell is 100% the same kit. I purchase mine in bulk from Tactrix.
Old Aug 14, 2009 | 04:33 AM
  #67
evo4mad's Avatar
Tactrix has now SOLD OUT of OpenPort2.0 not available until September 10th.
I still have a few left. But are going quickly.
Old Aug 14, 2009 | 12:00 PM
  #69
evo4mad's Avatar
Yeah the price is $197 until more stock is available, on the plus side, you now get a free OBDII extension cable, and free subaru and mitsubishi connectors.
Old Aug 14, 2009 | 01:00 PM
  #70
funks's Avatar
I ordered the openport 2.0 cable from your site a couple of days ago when it was still priced 169$ - did the 169$ price come with the mitsubishi (evo9 and below) and subaru reflash adapters?
Will you be selling the reflash adapters separately like the tactrix site? Additionally, will you be selling the odbii extension cable separately as well?
Old Aug 14, 2009 | 01:09 PM
  #71
vmrevo9's Avatar
Veteran: Air Force
wierd... my cable which i purchased with evoscan a while back works fine. my ACD lights flash while in idle but i dont have ABS (RS) so i never had an issue with it.
Old Sep 8, 2009 | 09:20 PM
  #72
Kingofvacuity's Avatar
Any update if the cables got back in stock or the price went down?
Old Sep 9, 2009 | 03:33 AM
  #73
evo4mad's Avatar
no-one in the world has any stock of OpenPort 2.0 left.
I will have more OpenPort 2.0 stock on 23rd Sept. You can Pre-order yours now, at the lower price again. I do however have plenty of OpenPort 1.3U in stock.
Old Sep 9, 2009 | 08:17 AM
  #74
Mellon Racing's Avatar
explains why my customers can't find one, I pointed one of them to your post.
Old Sep 9, 2009 | 09:42 AM
  #75
If I get the 1.3U, how can i use the wrx adapter so i can also flash my buddys 02 wrx?
