ELM327 Bluetooth & Evoscan/ECUflash
Old Nov 23, 2008 | 09:46 AM
unsungboxer's Avatar
For those of you using evoscan/ecuflash: Has anyone tried using the elm327 bluetooth instead of the evoscan or tactrix cables? If so what were your results? Pros/Cons?
Old Nov 23, 2008 | 11:03 PM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Unless you write your diagnostic software from scratch, it will not work.
The OBDII shall work according to ISO9141, but you will not get flashing, and many of MUT goodies.
Old Nov 24, 2008 | 06:49 AM
logic's Avatar
acamus is probably right; it probably behaves like most of the other ELM devices, which are pretty much OBD-II only.
Does anyone make a wireless device that's a simple pin-for-pin passthrough? I'm envisioning something you'd plug into the car permanently, with a paired device that has an OEM-style OBD-II plug on it. No translation like the ELM gadgets do, just a primitive wireless version of an OBD-II extension cable.
Old Nov 24, 2008 | 06:54 AM
acamus's Avatar
None that I know of, but I was playing with the idea of to put BT key at the end of taktrix cable, but the taktrix drivers, that ECUFlash and EvoScan relies on, are not open source so I ended up rigth there.
Old Dec 7, 2008 | 10:48 PM
acamus's Avatar
Lately I have found open source library (libmut) that explains the connection protocol, so probably I will write some application that is capable of connecting via BT. I am thinking about using my celular/mobile phone to display the main params and calculate consumption.
I have to start digging info on HW, how to extend tactrix cable for BT support.
Hopefully some HW guru's can help how to couple e.g. default broadcom CSR implementation to tactrix cable.
Old Dec 8, 2008 | 12:15 AM
acamus's Avatar
Ok I have found
http://www.csrsupport.com/download/3...R-ds-001Pb.pdf
or
http://www.blue2bfree.com/cms/data/bluemore106.pdf
This should be sufficient, if I am not mistaken
Old Jan 15, 2009 | 11:23 PM
acamus's Avatar
As Hamish is not going to help here, and wants to sell OP2.0 and GPS Touchscreen
I have been started by CLanZer, his software shall work with virtual COM ports, and should work with BlueTooth.
BT module that I have taken can be configured for non standard baudrate.
The S35 register is index value of baudrate.
Register S35 = Baud * 0.004096
Example : 15625 * 0.004096 = 64
One can set 15625 baudrate using ATS35=64 command.
My plan is to use my cellular for wireless monitoring, until then I shall find flaws of HW design with CLanZer's MUTMonitor.
So I spent little time to draw a schematics. If anyone wants to follow my steps here it is, it is not tested yet,
I will report back once I have done more.
Old May 1, 2009 | 01:00 PM
acamus's Avatar
Finally I got the logging part working.
Here is the the BT logging hardware.
Hopefully CLanZer will modify his software soon to support it.
@Hamish, Even if you do not believe BlueTooth, it works as charm.
Old May 4, 2009 | 02:29 AM
Mattjin's Avatar
Amazing effort! Closet genius I say.
Old May 4, 2009 | 03:23 AM
acamus's Avatar
Thank you Mattjin, it is not exceptional at all. Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. Even if I am not HW guru, I just persisted on my goal an applied all what is already available together.
Old Aug 21, 2009 | 12:35 PM
acamus's Avatar
Today I have borrowed one of generic OBD key. It is possible to get MUT communication (requests, commands and actuators with it)
Here is little how to
1. Open COM port of BT key, e.g. COM6 via HyperTerminal or write simple application
2. Set baudrate to 19200
3. Send ATSP0<CR><LF>
4. Wait for reply OK - (Bus Init..... OK)
5. Send A0<MUT ID><CR><LF> e.g. A032
6. Parse reply E0 <value> e.g. E0 80, so value is 0x80
7. Use formula to get the scaled value
Sure, the logging speed is slow, baudrate 10400, but the ELM based toys are really cheap.
Old Feb 8, 2013 | 12:03 PM
leecavturbo's Avatar
any advances? logging speed and more?
Old Feb 23, 2013 | 06:30 PM
GT35RX's Avatar
id like to know as well
BlackHawk_Tsi
Apr 17, 2015 05:39 AM
ihatemyusername
Apr 17, 2015 05:33 AM
CDrinkH2O
13
Apr 28, 2014 08:08 AM
Nemaris
Oct 15, 2013 05:23 AM
D@RK_L!GHT
May 19, 2013 07:52 PM
