converting 99860002
Old Sep 18, 2009 | 01:19 PM
MR Turco's Avatar
converting 99860002
Hey all,
I had a local ask me to help him with 99860002. He bought an imported evo 7. He lives in MA and needs to pass emissions. I know nothing about JDM or evo 7 roms.
Questions:
  • Can i convert to an evo 8 ecu or rom? He is willing to buy the 8 ecu if needed. I also need to do the readiness patch so being able to run an 8 rom is necessary.
  • Is there a specific evo 7 rom that has any sort of support? Looking for rear o2 removal.
  • Is the front o2 sensor heated? Had a problem with not having a heated front o2 on an evo 6 motor.
Any help would be much appreciated.
Old Sep 18, 2009 | 02:02 PM
evonut270's Avatar
has it failed an emissions test? the evo 7 does not have a rear 02 sensor AFAIK.the front 02 is heated.there are a few roms for the 7 available i doubt switching to an 8 ecu will help your cause.
Old Sep 18, 2009 | 04:24 PM
MR Turco's Avatar
it has failed for rear 02 but i can spoof it with the evo 8 ecu.
Old Sep 19, 2009 | 05:05 PM
MR Turco's Avatar
bump anyone?
Old Sep 19, 2009 | 09:33 PM
logic's Avatar
I can't speak to running an VIII ROM on that car, although there's definitely no architectural reason it shouldn't work (procs are the same, and interrupts look right to me). I'd give it a try if you have some leeway to do it with your customer; conversion should be the same as converting anyone else to 96530006, just copy the immobilizer and the additional hex value (we really need a better name for that; the traditional "immobilizer" is key-specific, while the other value is ROM-specific).
I have no clue about the front O2 heater, I'm afraid.
Looking through the code for that ROM, there doesn't appear to be any code for the heater test for the rear O2 (which suggests that there's no support for it at all), so I'm guessing the problem you're having with emissions is that the rear O2 tests are "not available", rather than "not ready"?
If so, I think this is the patch you want (referencing acamus' and mrfred's excellent work):
Code:
	<table name="Non-Continuous Monitor Availability Patch Part 1" category="OBD Inspection" address="2f620" type="1D" level="1" scaling="Hex16"/>
	<table name="Non-Continuous Monitor Availability Patch Part 2" category="OBD Inspection" address="2f666" type="1D" level="1" scaling="Hex16"/>
	<table name="Non-Continuous Monitor Completion Patch" category="OBD Inspection" address="2f66c" type="2D" level="1" scaling="Hex16">
		<table type="Static Y Axis" elements="2">
			<data>2F66C</data>
			<data>2F66E</data>
		</table>
	</table>
@2F66C DA51 -> EAFF
@2F66E 6AA1 -> 6AA7
from 4019 to E000
from 6AA1 to EAFF
Code:
	<table name="Monitor Available(1)/Not Available(0)" category="OBD Inspection" address="2f667" type="2D" level="2" scaling="blobbits">
		<table name="Non-Continuous Monitor Availability Bits" type="Static Y Axis" flipy="true" elements="8">
			<data>EGR system</data>
			<data>Oxygen heater sensor</data>
			<data>Oxygen sensor</data>
			<data>A/C system refrigerant</data>
			<data>Secondary air system</data>
			<data>Evaporative system</data>
			<data>Heated catalyst</data>
			<data>Catalyst</data>
		</table>
	</table>
	<table name="Monitor Passed(1)/Failed(0)" category="OBD Inspection" address="2f66d" type="2D" level="2" scaling="blobbits">
		<table name="Non-Continuous Monitor Completion Bits" type="Static Y Axis" flipy="true" elements="8">
		</table>
	</table>
Obviously that's totally untested, but might at least get you going. acamus, if you're reading this, can you confirm that the above looks right for that ROM? (This is my first time reading through some of this code. I need to get IDA loaded on my Windows laptop; I really miss the graphing in the Linux console version.)
Old Sep 20, 2009 | 01:00 PM
MR Turco's Avatar
logic, thank so much! I will try this out, when i can get my hands on the car, and get back to you.
thanks!
Old Sep 20, 2009 | 01:29 PM
Dennis F's Avatar
If this is the car I am thinking it is, I am very familiar with it.
When that car first came to MA it was stock and for a couple years had no problem passing the readiness checks. I believe somewhere along the line, it has been corrupted.
The car had no emissions and no rear o2 IIRC. The front sensor should be heated just like the 8 and 9.
I would honestly start with ringing out all the o2 sensor wires and make sure none of them have been switched at the ECU. For a while the car had a motec in it and there was some assetry going on with the tuner and I wouldn't be surprised if it has been hacked up some.
Keep in mind for an evo 8 ecu to work, you will have to spoof every emissions sensor including the EGR, MDP, and it also has a factory antilag in it.
Old Sep 21, 2009 | 03:05 AM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
It seems to be correct.
Old Sep 21, 2009 | 05:05 AM
MR Turco's Avatar
This is the same car you are thinking of. Hrmmm, this is some good info. I will talk it out with the local and see what the deal is.
Old Sep 21, 2009 | 05:12 AM
Dennis F's Avatar
Well, a lot of the hackery with the ECU was with the previous tuner on the motec.
I have no idea what is going on with it now though. But in order to switch to an 8 ecu, there are a couple pins that need to be switched. I think it is 8 and 22, but double check. It is the fuel pump and a/c circuit.
senate6268
Lancer Engine Management / Tuning Forums
703
Dec 5, 2022 02:44 AM
domyz
Jul 27, 2022 11:54 AM
mrfred
May 1, 2020 10:16 AM
ug_orf
Feb 19, 2016 09:26 AM
TouringBubble
Aug 3, 2015 09:15 PM
