need Evo 9 owner to test rear O2 *heater* sim patch
Old Oct 3, 2009 | 12:43 AM
  #286
SeanV's Avatar
Excellent work MrFred and Acamus.
Work liked a charm on my Evo using 95630006/96530706.
I used this patch over here and it worked perfectly.
Any chance of getting the same thing for the 88840016 Rom for a EDM Evo9.
Over here in South Africa, we don't have worry about emission testing/readiness codes etc.
Thx again..
Old Oct 5, 2009 | 11:06 AM
  #287
rdtech's Avatar
anything for the 96420011? Just curious. I would like to test it out.
Old Oct 11, 2009 | 08:54 AM
  #288
Monochrome's Avatar
Originally Posted by acamus
Thanks logic, you have just opened my eyes
Thinking it over again, I believe we do not even have to patch any rom for heater CEL we just need a definition like one below.
96940011
Code:
	<table name="Heater CEL" category="Rear O2" address="2E6AC" type="2D" level="2" scaling="blobbits">
		<table name="Bit values" type="Static Y Axis" flipy="true" elements="8">
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
			<data>Rear O2 Heater CEL Enable</data>
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
		</table>
	</table>
or
88590015
Code:
	<table name="Heater CEL" category="Rear O2" address="2DAFB" type="2D" level="2" scaling="blobbits">
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
		</table>
	</table>
mrfred, can you add them to the EcuFlash release?
Hey man, can you pretty plz write this for 96530006?
Old Oct 11, 2009 | 09:32 AM
  #289
donour's Avatar
You mean this?: https://www.evolutionm.net/forums/7077197-post241.html
Old Oct 11, 2009 | 10:36 AM
  #290
Monochrome's Avatar
Originally Posted by donour
Not exactly, I was asking for a one bit heater check on/off coding for 9653.
I THINK THIS WILL WORK but I need to confirm it. Not 100% sure if the address is correct.
Code:
	<table name="Heater CEL" category="Rear O2" address="2c61e" type="2D" level="2" scaling="blobbits">
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
		</table>
	</table>
Old Nov 14, 2009 | 09:27 AM
  #291
Kings Fan's Avatar
So I tried mrfred's patch on #59 and Acamus' on #267. I'm still getting the SES light after driving around for about 5 miles. Is it because I still have the O2 plugged in and not removed?
I copied mrfred's rom data and set acamus' rear o2 to "0". Anyone have thoughts? Thanks.
Old Nov 14, 2009 | 09:58 PM
  #292
Jeff_Jeske's Avatar
^ You are correct you have to unplug and remove the sensor or you'll probably get a slow response CEL. I've encountered this on a couple of friends cars.
BTW the code posted directly above your post works as well. Its confirmed.
Old Nov 14, 2009 | 10:50 PM
  #293
Kings Fan's Avatar
I think I realized these patches are just for the heater circuit and won't work for SES P0420. So I applied the patch here: https://www.evolutionm.net/forums/5353216-post148.html
If that doesn't work I'll look into removing the o2 sensor or just using a mechanical fix.
Old Nov 15, 2009 | 07:44 AM
  #294
scheides's Avatar
EvoM Moderator
Thx again..
So you run 96530706 and literally just did:
Code:
<table name="Rear O2 Heater Patch" category="Mods" address="2c62a" type="1D" scaling="Hex16" />
and changed "4A0B" to "0009" and that's it? I shall give this a try.
**edit** I tried it, it seems to work great! I have the rear o2 completely unplugged. I'll make sure nothing silly becomes of it over the next week but all seems fine for now.
Old Dec 22, 2009 | 08:46 PM
  #295
nonschlont's Avatar
ridding the ol' p0420
ok, I just skimmed thru this entire thread, and sorry if this has been asked but I just got a p0420 "catalytic efficiency below threshold" and am trying to confirm the correct method to disable the cell, and a lil confused, w/ all of the methods goin on here... I added the OBD inspection, the rear 02 (but didnt make the changes in ecuflash, as I still have the sensor installed) and the rear 02 heater cell.
I understand the OBD inspection has nothing to do w/ the cell. I also understand that if the sensor is still in place, cant use mrfred's method. And I just read that the rear 02 heater doesnt help the p0420 cell.
So my question is can I just disable FAA bit. 01? Or tephras rear 02 simulator?
Im not sure "the reason" for the cell, although I would like to know... Im running a mil-spec 100 cell, HFC w/ ~ 8K on it.. First time for this cell.
TIA
Old Apr 29, 2010 | 07:53 PM
  #296
logic's Avatar
Quick sanity check for anyone reading this: does the VII (that runs 90550001 natively) have a rear O2 sensor? It doesn't look like it does, but I could be reading this incorrectly.
Old Apr 29, 2010 | 07:55 PM
  #297
tephra's Avatar
dont think it does...
pretty sure 90550001 is the ralliart ecu romid so rear02 removed...
but hey - you will find out pretty soon if it expects one
Old Apr 29, 2010 | 08:00 PM
  #298
logic's Avatar
Heh, more like Mr_Turco. I looked up the OBD inspection stuff for him in 9055, and decided to take a quick peek to see if the rear O2 heater code was the same, and...er...didn't find any code.
Old Apr 29, 2010 | 08:14 PM
  #299
tephra's Avatar
yeah he asked me last night if 90550001 will run on whatever rom he currently had...
it should be fine... i dont think there is any wiring differences between Evo7's...
Old Apr 30, 2010 | 05:03 AM
  #300
MR Turco's Avatar
yeah, i wanted a rom with some tephra support plus i don't have a lot of non-usdm definition files so this one seems to have what i need. It needs to pass the emissions tests which is only reason i have to care about this stuff . Thankfully logic is hooking me up with the goods.
