need Evo 9 owner to test rear O2 *heater* sim patch
Old Jul 21, 2009 | 09:30 AM
  #271
Z_Lancer_Man's Avatar
Originally Posted by acamus
use either #59 or #267 to remove rear 02 heater CEL.
use #117 or watch this if you want safely pass the inspections.
Well I've tried #59 with no luck, so I'll give #267 a try for CEL elimination. I'll also check out that video. Thanks!
Old Jul 21, 2009 | 06:06 PM
  #272
Monochrome's Avatar
Thanks logic, you have just opened my eyes
Thinking it over again, I believe we do not even have to patch any rom for heater CEL we just need a definition like one below.
96940011
Code:
	<table name="Heater CEL" category="Rear O2" address="2E6AC" type="2D" level="2" scaling="blobbits">
		<table name="Bit values" type="Static Y Axis" flipy="true" elements="8">
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
			<data>Rear O2 Heater CEL Enable</data>
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
		</table>
	</table>
mrfred, can you add them to the EcuFlash release?
Maybe a stupid question, but to disable the CEL, I need to change the 1 to a 0 correct? It won't let me do it manually.
Old Jul 21, 2009 | 08:00 PM
  #273
logic's Avatar
Just select the value, and press the "[" key. It's a little interface bug with EcuFlash, you can't actually edit bit values directly, you have to increment ("]") or decrement ("[") them instead.
Old Jul 22, 2009 | 06:43 AM
  #274
Monochrome's Avatar
Ah that's right. Figured it was something simple.
Now how come when I apply both yours and acamus patch one doesn't effect the other? Is yours setting the test to pass and his just disabling the test all together?
Old Jul 22, 2009 | 08:53 AM
  #275
logic's Avatar
Erm. You should only do one of the two.
Mine disables the code in a rather crude way, while his makes it a simple toggle in EcuFlash; basically, if you apply mine, his toggle won't ever let you turn it back on again. I'd argue that his approach is much more reasonable.
I should probably just delete my entries at this point, in lieu of a post giving XML definitions for all ROMs like acamus did above for 96940011 and 88590015.
Old Jul 22, 2009 | 09:44 AM
  #276
fostytou's Avatar
EvoM Community Team
I would personally say don't delete them but put a pointer to the new method... just in case. Information is valuable
When using Acamus/logic's newer patch to just disable the check, does it continue to heat the O2 sensor if plugged in or does it skip the routine that activates the heater also?
Thanks!
Old Jul 22, 2009 | 10:27 AM
  #277
Monochrome's Avatar
I haven't flashed this to my car. Was just curious how they both worked.
Old Jul 22, 2009 | 09:51 PM
  #278
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
The heater part of the code is doing its job, it is only CEL that is not stored/shown.
Old Jul 23, 2009 | 06:56 PM
  #279
Monochrome's Avatar
Rear O2 has been removed, LC-1 installed in it's place. Applied the heater patch along with the rear 02 sim patch and went out for a brief drive. So far, no CE light. No periphery bits have been disabled and no resistors have been installed.
Tomorrow I'll be on the road for 6 hours so that'll be more than plenty of time for the ECU to run the checks.
After that, it's off to autozone to test and see what all the stock EVO8 readiness checks are before applying the force pass/readiness patch.
Thank you Logic, acamus, and Recompile!
Old Aug 8, 2009 | 07:09 PM
  #280
krazykorean84's Avatar
Can someone explain the specific differences between Mr Fred's Heater sim (post #59) and the Acamus Heater mod (post #267)? Does Mr Fred's patch actually simulate the heater and Acamus' mod just disables the CEL? Thanks in advance.
Old Aug 9, 2009 | 01:12 AM
  #281
acamus's Avatar
The difference is that mrfreds patch is calling function that stores the CEL in case of rear O2 heater with the non-error values. Mine, skips storing of this value (error / non-error)
Old Sep 3, 2009 | 06:06 PM
  #282
RAbishi's Avatar
I just used the method posted in post #267 and it worked great. Thanks guys!
Old Sep 26, 2009 | 01:25 AM
  #283
black-dsm's Avatar
what about to those that are using the 96530006 rom? Can I use the code from 96940011?
Old Oct 2, 2009 | 10:50 PM
  #284
rdtech's Avatar
This is great news. I'll be testing it out on my 8 to see if everything is dandy.
Old Oct 2, 2009 | 11:39 PM
  #285
rdtech's Avatar
anything for the 96420011? I would like to test it out on my evo
