need Evo 9 owner to test rear O2 *heater* sim patch
Excellent work MrFred and Acamus.
Work liked a charm on my Evo using 95630006/96530706.
I used this patch over here and it worked perfectly.
Any chance of getting the same thing for the 88840016 Rom for a EDM Evo9.
Over here in South Africa, we don't have worry about emission testing/readiness codes etc.
Thx again..
Thx again..
Thanks logic, you have just opened my eyes
Thinking it over again, I believe we do not even have to patch any rom for heater CEL we just need a definition like one below.
96940011
or
88590015
mrfred, can you add them to the EcuFlash release?
96940011
Code:
<table name="Heater CEL" category="Rear O2" address="2E6AC" type="2D" level="2" scaling="blobbits"> <table name="Bit values" type="Static Y Axis" flipy="true" elements="8"> <data>N/A</data> <data>N/A</data> <data>N/A</data> <data>N/A</data> <data>Rear O2 Heater CEL Enable</data> <data>N/A</data> <data>N/A</data> <data>N/A</data> </table> </table>
88590015
Code:
<table name="Heater CEL" category="Rear O2" address="2DAFB" type="2D" level="2" scaling="blobbits"> <table name="Bit values" type="Static Y Axis" flipy="true" elements="8"> <data>N/A</data> <data>N/A</data> <data>N/A</data> <data>N/A</data> <data>Rear O2 Heater CEL Enable</data> <data>N/A</data> <data>N/A</data> <data>N/A</data> </table> </table>
You mean this?: https://www.evolutionm.net/forums/7077197-post241.html
I THINK THIS WILL WORK but I need to confirm it. Not 100% sure if the address is correct.
Code:
<table name="Heater CEL" category="Rear O2" address="2c61e" type="2D" level="2" scaling="blobbits"> <table name="Bit values" type="Static Y Axis" flipy="true" elements="8"> <data>N/A</data> <data>N/A</data> <data>N/A</data> <data>N/A</data> <data>Rear O2 Heater CEL Enable</data> <data>N/A</data> <data>N/A</data> <data>N/A</data> </table> </table>
So I tried mrfred's patch on #59 and Acamus' on #267. I'm still getting the SES light after driving around for about 5 miles. Is it because I still have the O2 plugged in and not removed?
I copied mrfred's rom data and set acamus' rear o2 to "0". Anyone have thoughts? Thanks.
^ You are correct you have to unplug and remove the sensor or you'll probably get a slow response CEL. I've encountered this on a couple of friends cars.
BTW the code posted directly above your post works as well. Its confirmed.
If that doesn't work I'll look into removing the o2 sensor or just using a mechanical fix.
Thx again..
Thx again..
Code:
<table name="Rear O2 Heater Patch" category="Mods" address="2c62a" type="1D" scaling="Hex16" />
**edit** I tried it, it seems to work great! I have the rear o2 completely unplugged. I'll make sure nothing silly becomes of it over the next week but all seems fine for now.
ridding the ol' p0420
ok, I just skimmed thru this entire thread, and sorry if this has been asked but I just got a p0420 "catalytic efficiency below threshold" and am trying to confirm the correct method to disable the cell, and a lil confused, w/ all of the methods goin on here... I added the OBD inspection, the rear 02 (but didnt make the changes in ecuflash, as I still have the sensor installed) and the rear 02 heater cell.
I understand the OBD inspection has nothing to do w/ the cell. I also understand that if the sensor is still in place, cant use mrfred's method. And I just read that the rear 02 heater doesnt help the p0420 cell.
So my question is can I just disable FAA bit. 01? Or tephras rear 02 simulator?
Im not sure "the reason" for the cell, although I would like to know... Im running a mil-spec 100 cell, HFC w/ ~ 8K on it.. First time for this cell.
TIA
TIA
Quick sanity check for anyone reading this: does the VII (that runs 90550001 natively) have a rear O2 sensor? It doesn't look like it does, but I could be reading this incorrectly.
Heh, more like Mr_Turco.
I looked up the OBD inspection stuff for him in 9055, and decided to take a quick peek to see if the rear O2 heater code was the same, and...er...didn't find any code.
yeah, i wanted a rom with some tephra support plus i don't have a lot of non-usdm definition files so this one seems to have what i need. It needs to pass the emissions tests which is only reason i have to care about this stuff
. Thankfully logic is hooking me up with the goods.
