Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Modify stock exhaust to remove flapper
Old Oct 22, 2009 | 04:21 PM
mrMTB's Avatar
I would have sworn I'd seen a writeup on this, but cannot find it anywhere. Can anyone point me in the right direction? Anyone aware of a dyno comparison between stock and the flapper removed?
TIA
Old Oct 22, 2009 | 04:38 PM
UT_EvoX's Avatar
It's not the flapper you remove (you can to reduce the vibrations afterward) but the pipe that connects the two side chambers of the muffler.
Also, I did a dyno comparison in DLL.
Darker lines are the "after."
Old Oct 22, 2009 | 05:39 PM
blk-majik's Avatar
How did you know where to cut? Looks like you nailed the locations perfectly.
Old Oct 22, 2009 | 07:02 PM
Ltdanish07's Avatar
nice gains considering what was done.
Old Oct 22, 2009 | 08:17 PM
mrMTB's Avatar
Rock on dude! That's exactly what I was looking for.
Old Oct 22, 2009 | 08:49 PM
4G63kevin's Avatar
what does it actually do?
Old Oct 22, 2009 | 10:37 PM
Grip Master's Avatar
How much louder did it make the exhaust?
Old Oct 22, 2009 | 11:04 PM
UT_EvoX's Avatar
Take a look here at the guts of the Evo X muffler: http://www.worksevo.com/store/produc...roducts_id=502
By removing that pipe, you bypass that convoluted internal routing and allow the exhaust to flow into the muffler and directly out the tailpipes.
You can definitely tell the muffler is free flowing after the mod. Has a nice growl, but hardly louder than stock.
http://s159.photobucket.com/albums/t...t=100_3040.flv
That's a crappy vid clip with lots of BG noise, but you get the idea. Nice and subtle still.
Old Oct 30, 2009 | 08:58 AM
Anyone know what the stock muffler is made out of? Stainless? Galvinized steel? Thanks
Old Nov 2, 2009 | 07:09 AM
speedmaster747's Avatar
Now a days I think all cars have stainless, they last a lot longer!
Old Nov 2, 2009 | 08:17 AM
blueberryyumyum's Avatar
seems a lot of work to do by yourself.. prob would recommend a shop to do this lol
Old Nov 2, 2009 | 08:22 AM
UT_EvoX's Avatar
It's definitely stainless, but probably crappy T409 (since it was rusting already). I didn't have any stainless wire, so I just welded it back up with mild.
Not really... took me no more than 30 minutes to do the whole job. The muffler part itself takes 15-20 min at most. All you need is a sawzall and a welder. Easy peasy
But then again I tackled a clutch install on the X in the same exact spot in my driveway... I'm just dedicated and cheap.
Old Nov 2, 2009 | 08:55 AM
Mendo's Avatar
noob question here, no CELs?
Old Nov 2, 2009 | 08:57 AM
mrMTB's Avatar
Shouldn't cause any CEL. You're pretty much home free after the back O2 sensor.
Old Nov 2, 2009 | 08:58 AM
mrMTB's Avatar
Mendo, just noticed you're in Dallas - Denver at Evo Dynamics is doing mine.
