Evoscan Navigator in Evo X? Yes please !!!
Old Feb 17, 2010 | 01:47 PM
  #61
Yousef's Avatar
Originally Posted by SiC
Okay, make sure it has mode23 enabled or else you wont be able to log with Evoscan.
Aha ok, lets say it might not be enabled, can u plz tell me how to enable it? Thank u
Old Feb 17, 2010 | 01:53 PM
  #62
SiC's Avatar
SiC
If your tuner used ECUFlash to tune, more than likely he used Evoscan for logging. So I would think he enabled mode23. Also, can you ask your tuner what vehicle setting he used in Evoscan (more than likely JDM 2009).
If mode 23 isn't enabled, you can find all the info here for mode 23:
Evo X Logging
Old Feb 17, 2010 | 01:58 PM
  #63
Yousef's Avatar
Evo X Logging
I will ask him first thing in the morning it is 2am now
btw i am a graphics designer i can help with gtaphics stuff
Old Feb 17, 2010 | 11:40 PM
  #64
Yousef's Avatar
ok SiC
I just tested EvoScan..
All settings worked, however I like JDM 2008 because it has SST temp
please tomorrow 19/2 10:00AM GMT+4 is my trackday and it would be nice if I have evoscan gps for data logging
Thanx
update: my tuner just confirmed that he used JDM
Old Feb 18, 2010 | 11:33 AM
  #65
stokEd's Avatar
Originally Posted by ApexSilverXGSR
On the evoscan.org site it says that you choose the GPS software & maps, so couldn't you use the garmin option for better quality navi functioning?
I've had 2 standalone gps systems by tomtom and they both royally sucked and crapped out within months. I'm in it for the evoscan function, but the navi is big boost in appeal... Guess we all should wait a while for it to be developed a bit more? Wish someone in the US would come out with something like this.
It's a problem with the hardware (built-in gps antenna weak) not the software. If you're going to buy a unit and plan to use navigation you need to get an external antenna (plugs into a port on the back.) I have a GILSSON (~$25) and it was the only way I could get the navigation to work. And as far as Garmin being superior to iGo, I've never compared the two so I can't say.
Date: 2009-10-01 00:42:37
Message:
Hi Eddie,
Yes this is common phenomina with current GPS device technology, the EvoScan GPS Navigator uses the latest SirfIII GPS technology, on occasion it can take up to 25 minutes for a good satellite lock to take place. I have noticed the best and fastest way to get a gps lock, is to have a clear sky, and to be outside in one spot for approx 5-10minutes. The EvoX features are currently in development, I will keep you updated.
Regards,
Hamish Ahern.
http://www.limitless.co.nz/EvoScan
http://www.limitless.co.nz/Cables
Old Feb 18, 2010 | 01:51 PM
  #66
SiC's Avatar
SiC
Hamish informed me he sent out ppc 1.7 to around 20 gps/nav customers for testing on the EvoX. If you are one of the lucky ones, you should have already received it.
Old Feb 20, 2010 | 05:56 PM
  #67
stokEd's Avatar
Got it!
Old Feb 21, 2010 | 01:46 AM
  #68
_Speedy_'s Avatar
yeah my 5inch GPS can get a signal lock within 60 seconds. My EvoScan unit always takes 4minutes to get a lock, but once EvoScanGPS has a lock, it has perfectly good signal and never looses the satellites.
Old Feb 21, 2010 | 01:54 AM
  #69
_Speedy_'s Avatar
Here is an image showing a normal GPS with good green signal on the iGo software, and an EvoScanGPS on the right of the picture. EvoScanGPS can find more satellites in the sky although sees a lower signal strength for each satelitte. The 2nd image attached is the signal within EvoScanGPS software after the warmup period of 3-5minutes with EvoScanGPS.(thats assuming your device goes flat and has to start from cold boot, warm boot seems to give me 10seconds GPS lock time on the EvoScanGPS.
Attached Thumbnails Evoscan Navigator in Evo X? Yes please !!!-gps_095.jpg   Evoscan Navigator in Evo X? Yes please !!!-gps_096.jpg
Old Feb 21, 2010 | 09:09 AM
  #70
Yousef's Avatar
Custom SST gauges I am working on, still work in progress, some fonts need resizing and alignment
sorry 4 crappy iphone 3g photo
Old Feb 21, 2010 | 01:12 PM
  #71
SiC's Avatar
SiC
Yousef, I guess you figured out how to log the SST temp
Old Feb 22, 2010 | 02:20 AM
  #72
E6-X's Avatar
anybody mind sharing some custom gauge layouts ? yousef, yrs looks goood
Old Feb 22, 2010 | 02:35 AM
  #73
Yousef's Avatar
yup its all in the template file, I am trying to log battery as well, do you know the item name? "Battery" did not work
I am not sure if i am allowed 2
If yes, give me some time to finalize it
Old Feb 22, 2010 | 02:43 AM
  #74
SiC's Avatar
SiC
Open up your data.xml file and paste this into the "Mode23 2009 JDM EVOX" section:
Code:
        <DataListItem DataLog="Y" Color="" Display="Battery Level" LogReference="Battery" RequestID="CAN0-0" Eval="0.07333*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="16" ChartMin="0" ChartMax="16" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
You can distribute templates but not the software itself
Old Feb 25, 2010 | 02:58 AM
  #75
_Speedy_'s Avatar
Yousef that looks really cool. He said the next version is going to have bargauges with peak hold etc. and also image buttons (arrows) to cycle between gauge template files, so you better start leaving some space for some image buttons (arrow things) on your gauge graphics
