Evoscan Navigator in Evo X? Yes please !!!
Old Apr 19, 2010 | 10:54 PM
  #106
tephra's Avatar
it *should*
the CAN stuff is the oldest, but probably the least well tested..
But that should give you the basic...
Old Apr 20, 2010 | 12:54 AM
  #107
evoscan's Avatar
Silver Sponsor
OBDII CAN is not enabled on GPSNav, it really has nothing of interest. Mode23 has all the real stuff and factory CAN OBDII scantools still work even with mode23 enabled, so no problems there.
Old Apr 20, 2010 | 08:22 AM
  #108
CatalystGod's Avatar
Wait a sec, if I am to interpret that correctly, I need to have Mode23 enabled to used the GPSNav as of today. Is that correct?
Also, if you could please, what about my other questions?
5) I also have the LC1 wideband installed. tried connecting just the LC1 to the unit to try and log just the AFR, but it looks like OP2.0 connection is a MUST.
6) connected a USB hub to the Y adapter . I confirmed it to be working on my computer before doing this. I then connected both the LC1 and the OP2.0. In this case, it fails saying that its unable to initialize the LC1 wideband. The red - light is steady on the LC1.
Any ideas ????
Also, the GPS screenshots on the first page say evoscan version 2.7 !!!! was the versioning changed after the fact?
Old Apr 20, 2010 | 11:46 AM
  #109
stokEd's Avatar
Yes, that's what he's saying.
And I don't have experience with the LC-1 so I can't help you there.
Old Apr 20, 2010 | 12:40 PM
  #110
Ok then, mode 23, here I come !!!
Old Apr 20, 2010 | 12:53 PM
  #111
kmart888's Avatar
Question How to enable mode23?
I'm a complete novice, never used Evoscan as all my tuning was done with Cobb AP in ATR, I just got the Evoscan GPS in the mail (without a user's manual) and I planned on using it as a gauge pod and logger, it is running on my desk right now as I have not yet connected it to my OBD II port, just trying figure out how to use it without any direction. I just read above that I have to have something called mode23 enabled before I can use the GPS as a gauge, how do enable mode23? Remember I have zero experience with the Evoscan software, any ECM manipulation I have done previously is in ATR.
Old Apr 20, 2010 | 12:58 PM
  #112
stokEd's Avatar
Enabling mode 23 is straightforward; instructions are here:https://www.evolutionm.net/forums/ev...lustrated.html
Old Apr 20, 2010 | 04:06 PM
  #113
kmart888's Avatar
This is straightforward? All I want to do is use the EvoScan touchscreen gps as a guage and logging tool, do I have install EvoScan windows 2.6 on a laptop, learn the windows version of EvoScan, connect the laptop to he ECM and follow referenced "proceedure" before I can use the touchscreen gps for my intended purpose?
Plug and play (I was hoping) this is not!
Old Apr 20, 2010 | 04:07 PM
  #114
HB Speed's Avatar
This is straightforward? All I want to do is use the EvoScan touchscreen gps as a guage and logging tool, do I have install EvoScan windows 2.6 on a laptop, connect the laptop to he ECM and follow some "proceedure" befor I can use the touchscreen gps for my intended purpose?
you cant
AP will not work with mode 23
Old Apr 20, 2010 | 04:13 PM
  #115
kmart888's Avatar
It would help if somewhere, anywhere, there was a user's manual or at the very least a tutorial for beginners that did not require previous expertise in EvoScan software!
Frustrated
Old Apr 20, 2010 | 04:17 PM
  #116
kmart888's Avatar
Originally Posted by HB Speed
you cant
Can I use the touchscreen GPS scantool as a gauge and logger with my AP flashed ECM (it looked so cool in the thread I jumped in without looking first ) or should I sell it?
Old Apr 20, 2010 | 07:30 PM
  #117
Golden's Avatar
Well... you could swap your tune from the AP over to evoscan and then use it.
Copp installs it's own custom "program" if you will to your ECU. The evoscan stuff won't work with it.
Old Apr 20, 2010 | 08:19 PM
  #118
Yeah, unfortunately, given how new the compatibility with the Evo X is, that seems to be the only current way of doing it, but eventually, we should not need to do things that way.
Old Apr 21, 2010 | 12:30 AM
  #119
evoscan's Avatar
Silver Sponsor
if it was plug and play, it wouldn't be our hobby We all here like to learn more and more about how the car works yeah mode23 is not plug and play I know. but its the best way we have.
Old Apr 21, 2010 | 06:51 AM
  #120
I'm asuming this is Hamish or somebody at evoscan. Can you please address my questions about the LC1. Has this functionality been tested? Have any of your customers reported this to be working/not working? I'm not trying to knock on the product, I'm willing to do my part in getting this functionality up to speed.
Unchecking everything except external Wideband also does not work. I do not see why I'd need mode23 enabled in this case. Or will I?
