Ecu based fan control ?
Old Jun 11, 2010 | 05:47 AM
TJung's Avatar
Like in title...
Is it possible to control for example fan speed or turn-on moment via ecu ?
Old Jun 12, 2010 | 02:33 AM
knochgoon24's Avatar
I've been trying to track down some solid answers on this too. I know you can, but I'd like to know table locations, especially for the 9653xxxx based roms.
Old Jun 12, 2010 | 03:30 AM
TJung's Avatar
Yeah, that's exactly what I search for - table locations. For now - I just installed switch which I use to turn on fan, when I want. But controlling fan via ecu would be great thing.
Old Jun 12, 2010 | 03:34 AM
MR. EVO MR's Avatar
you can turn it off and on via evoscan
Old Jun 12, 2010 | 08:28 AM
Deepnine's Avatar
search for thermo fan
there are maps in most roms.
i can give you more details tomorrow.
Old Jun 12, 2010 | 08:58 AM
nightwalker's Avatar
the 941705 v7 roms have thermo fan control. look up merlin's tuning guide, he goes over the fan control
Old Jun 12, 2010 | 09:52 AM
TJung's Avatar
Thanks !
Old Jun 12, 2010 | 01:30 PM
What ROM are you using? I spend the last hour or so searching on here and found the 96530006 based maps.
PHP Code:
    <table name="Thermo Fan Duty 0-22kph" category="Fan Control" address="575c" type="3D" level="2" swapxy="true" scaling="Percent (128)">
        <table name="Conditions" type="Static X Axis" elements="3">
            <data>Main Fan 0-22kph</data>
            <data>A/C Fan 0-22kph</data>
            <data>Main+A/C 0-22kph</data>
        </table>
        <table name="Engine Temp" address="6a14" type="Y Axis" elements="12" scaling="Temp"/>
    </table>
    <table name="Thermo Fan Duty 22-52-82kph" category="Fan Control" address="45ac" type="3D" level="2" swapxy="true" scaling="Percent (128)">
        <table name="Conditions" type="Static X Axis" elements="9">
            <data>Main Fan 20-50kph</data>
            <data>Main Fan 50-80kph</data>
            <data>Main Fan 80->>kph</data>
            <data>A/C Fan 20-50kph</data>
            <data>A/C Fan 50-80kph</data>
            <data>A/C Fan 80->>kph</data>
            <data>Main+A/C 20-50kph</data>
            <data>Main+A/C 50-80kph</data>
            <data>Main+A/C 80->>kph</data>
        </table>
    </table>
And now w/ headers for those of us still using imperial units...
PHP Code:
    <table name="Thermo Fan Duty 0-12mph" category="Fan Control" address="575c" type="3D" level="2" swapxy="true" scaling="Percent (128)">
            <data>Main Fan 0-12mph</data>
            <data>A/C Fan 0-12mph</data>
            <data>Main+A/C 0-12mph</data>
        </table>
    </table>
    <table name="Thermo Fan Duty >12mph" category="Fan Control" address="45ac" type="3D" level="2" swapxy="true" scaling="Percent (128)">
            <data>Main Fan 12-31mph</data>
            <data>Main Fan 31-50mph</data>
            <data>Main Fan 50->>mph</data>
            <data>A/C Fan 12-31mph</data>
            <data>A/C Fan 31-50mph</data>
            <data>A/C Fan 50->>mph</data>
            <data>Main+A/C 12-31mph</data>
            <data>Main+A/C 31-50mph</data>
            <data>Main+A/C 50->>mph</data>
        </table>
    </table>
Which gets you a table like this:
Old Jun 12, 2010 | 03:23 PM
TJung's Avatar
I am using 88590015 with v5.10
Old Jun 12, 2010 | 05:51 PM
RoadSpike's Avatar
Something like this then.
PHP Code:
    <table name="Thermo Fan Duty 0-12mph" category="Miscellaneous" address="5186" type="3D" level="2" swapxy="true" scaling="Percent (128)">
        </table>
        <table name="Engine Temp" address="7034" type="Y Axis" elements="12" scaling="Temp"/>
    </table>
    <table name="Thermo Fan Duty >12mph" category="Miscellaneous" address="4012" type="3D" level="2" swapxy="true" scaling="Percent (128)">
        </table>
    </table>
Old Jun 12, 2010 | 06:47 PM
lan_evo_mr9's Avatar
Interesting, I tried this with V7 and no go...tables are greyed out (invalid or incomplete). Any ideas?
Old Jun 12, 2010 | 07:15 PM
RoadSpike's Avatar
Mine are?
I copied them from a working xml file strange..
Old Jun 12, 2010 | 10:05 PM
Figured it out...
Old Jun 12, 2010 | 11:30 PM
RoadSpike's Avatar
Figured it out...
care to share the resolution?
Old Jun 13, 2010 | 12:49 AM
TJung's Avatar
PHP Code:
        </table>
    </table>
        </table>
    </table>
WoW, thanks !
