Ecu based fan control ?
Old Sep 22, 2010 | 03:21 PM
  #31
knochgoon24's Avatar
It does allow you to change when the fans kick on.
Even in your ROM patched with the OBDII for pass, the fan control table will still be there. Just add the correct tables to your xml.
Old Sep 22, 2010 | 03:24 PM
  #32
compscibOi's Avatar
Very sick. What are the conditions you all are using to trigger the fan?
Old Sep 23, 2010 | 07:14 AM
  #33
EvoDan2004's Avatar
Ok so I just copy and paste that table into my XML and I'm good to go?
Old Sep 23, 2010 | 10:35 AM
  #34
Should be.
For me, I was more concerned with getting the A/C fan to have 100% duty cycle since I'm using an Evo 8 Ecu in my 2g Talon. Our fans aren't PWM controlled, and low duty cycle on the A/C fan wasnt' the best thing for our relays controlling the fans.
I also adjusted it so my fans kick on a little bit sooner, especially the A/C fan. My car was getting a little warm, and having the A/C fan kick on with the rad fan helped a lot.
Old Jan 30, 2013 | 12:32 PM
  #35
CRONZ305's Avatar
is there a way to log to see when the fan comes on?
RSMike
11
May 10, 2018 05:43 AM
supersnow
May 25, 2016 02:53 PM
foxbear2277
Aug 16, 2012 05:09 PM
jameswwt
Dec 3, 2011 03:33 AM
Deepnine
Jul 8, 2009 06:05 AM
