Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Lancer 5-lug & Rear Disc Conversion Part List
Old Jul 14, 2010 | 04:58 PM
  #46
link62's Avatar
Originally Posted by WilliePetesOZ
Ok im really really sorry for withholding information but ive been running this setup for almost most a year now. I have 1g diamante twin calibers with galant vr4 rotors in the front and 3g mirage rotors, calibers and brake bracket in the back. I installed a 3000gt proportioning vavle to add more power to the brakes and everything works out perfect. The car stops way better with this brake setup than factory, enough to throw the balance of the front wheels.
i have a similar setup i run mini cooper s rotors, diamante twin calipers with 276 font rotors and 1g eclipse calipers in the back with a custom bracket for it
Old Jul 14, 2010 | 05:00 PM
  #47
DriftRunSir's Avatar
damn you link. you got the rear disc conversion kit already? lol nice.
Old Jul 14, 2010 | 05:38 PM
  #48
link62's Avatar
lol yea i converted the rear
Old Jul 14, 2010 | 08:12 PM
  #49
zulu989's Avatar
i wanna do this sooo bad
Old Jul 15, 2010 | 08:12 AM
  #50
WilliePetesOZ's Avatar
Its actually pretty easy to do. I think the hardest thing was the parking brake cable hook up.
Old Jul 15, 2010 | 03:41 PM
  #51
burner67's Avatar
hey im workin on this conversion tryin to gather the parts but i cant find the brake hard lines anywhere! anyone know the length of the lines??
Old Jul 15, 2010 | 04:26 PM
  #52
senate6268's Avatar
http://www.mitsubishiparts.net/cart/?pn=MR493468
http://www.mitsubishiparts.net/cart/?pn=MR493469
About $5 for each side.
Old Jul 15, 2010 | 06:20 PM
  #53
zulu989's Avatar
can any one make a breakdown of the different ways to do this with the parts needed..?
Old Jul 16, 2010 | 10:28 AM
  #54
burner67's Avatar
hey senate I called that online store you had the link to... and they don't have them either and they couldn't get ahold of them either because he said they checked and NO dealers or parts shop has those. I guess I will just have to get the brake line and bend it myself.
Old Jul 16, 2010 | 01:55 PM
  #55
senate6268's Avatar
I called the Mitsu dealer I get stuff from and they said they could order them both for next week. It's not a part they stock, but it's one they can order. Nobody is going to have them in stock, they are specialty order only. This is why those links indicate that they "usually ship in 4-10 business days".
Old Jul 18, 2010 | 07:22 PM
  #56
burner67's Avatar
is that how small the rotor is?? Where did you get that rotor anyways? looks spendy
Old Jul 18, 2010 | 07:36 PM
  #57
its slightly smaller than the front OEM rotors off a Lancer. rotor is Ford Focus or Mini Cooper.
Old Jul 20, 2010 | 06:39 AM
  #58
zulu989's Avatar
How can I convert my rear breaks to disk without switching to 5 lugs and what parts would I need
Old Jul 20, 2010 | 12:06 PM
  #59
when i did my rear brake swap i used the brakes from an early 90s mirage sedan. the caliber bracket is almost a direct bolt on. i had to make the bolt holes bigger so the hub would fit in without rubbing( and that is a really tight fit). the whole swap is the same as what the 5g mirage do. another thing is a week after i finished it i noticed that the rear rotors were larger than the front
Old Jul 20, 2010 | 12:19 PM
  #60
i just realised that link62 has an es which runs a 4-110 hub and my oz is a 4-114 hub. if you wanted use the galant vr4 or 3g mirage rotors then you would have to switch all the hubs to 4-114 or do it like link did.
