alpine install 900bt
Old Apr 5, 2011 | 07:36 PM
dizaryl's Avatar
This is my ongoing attempt to install an alpine 900bt. Hope it helps.alpine install 900bt-alpine900bt-small-.jpg
armrest hub with panel mount usbs for logworks/ evotune /ipod and a 3.5 stereo adapteralpine install 900bt-armrest-panel-mount-usb-ipod-small-.jpg
top view of removed armrest with bluetooth and imprint module for RCAs to passenger seat[ATTACH]alpine install 900bt-bluetooth-stealth-imprint-small-2-.jpg[/ATTACH]
cutout for imprint mic access alpine install 900bt-imprint-driverside-small-.jpg
first time with pics hope it worked
Attached Thumbnails alpine install 900bt-bluetooth-stealth-imprint-small-.jpg
Old Apr 8, 2011 | 12:35 PM
wickedevos's Avatar
nice
Old Apr 8, 2011 | 07:20 PM
FJF's Avatar
FJF
Originally Posted by dizaryl
This is my ongoing attempt to install an alpine 900bt. Hope it helps.Attachment 168100
armrest hub with panel mount usbs for logworks/ evotune /ipod and a 3.5 stereo adapterAttachment 168101
I completely missed this thread. Really like how you did the armrest.
Old Apr 8, 2011 | 07:41 PM
RonPattonJr's Avatar
yeah how did you do the arm rest, getting the ports installed cleanly.
Old Apr 8, 2011 | 11:05 PM
dizaryl's Avatar
Start with panel mount usbs and 3.5 mm stereo jack. I ordered mine from l-com but make sure you buy everything you need (3 ft is to short for cables) before committing to the $10+ shipping. Secret to the ports is having the items in hand and undersizing the cuts with dremel multimaster/rigid job max or any other vibrating cutter from the removed backside of the armrest cubby. Just file away the rest and tension fit. Drill thru (from the back) once tension fitted for #4 bolts (I think thats the right size but if the drill bit or bolt is to big for the panel mount hole; go smaller if they make them). Remember it's plastic; high speed, absolutely no pressure on the drill bit, remove burrs and melt. Make sure to have a small round file for the corners. Don't forget to order the "guide" cable for the imprint if doing this install. I got away with a straight, but a 90 degree composite cable would be ideal.
Old Apr 16, 2011 | 08:00 PM
dizaryl's Avatar
Imitation is the best form of flattery FJF
[attach][attach][attach]alpine install 900bt-underseat-mid4-small-.jpg[/attach][/attach][/attach]
Attached Thumbnails alpine install 900bt-underseat-mid1-small-.jpg   alpine install 900bt-underseat-mid2-small-.jpg   alpine install 900bt-underseat-mid3-small-.jpg
jake33
Apr 13, 2015 07:53 PM
EvoCecilia
Oct 24, 2012 09:44 PM
Tvall13
10
Jun 18, 2012 03:45 PM
ron2003
Feb 15, 2012 04:41 PM
Flip
16
Jul 13, 2010 12:30 PM
