2009+ Lancer RalliArt Sedan & RA Sportback Wheels/Tires Fitment
Old Apr 19, 2011 | 01:16 AM
  #571
sicae2k's Avatar
hello.
I just installed enkei ekm3 gunmetal 18x8J ET40 with stock tyres on my car. I really like the look and feel. It looks more aggressive in reality than in the pictures.
Old Apr 19, 2011 | 10:11 AM
  #572
evil03's Avatar
Originally Posted by robyn402
thats sexy, what kind fender work did you have to get done? and how much neg camber?
and is your rubber actually going all the way to the rim?
front is -2.5 rear is -2.0
tires are slightly stretched
Old Apr 19, 2011 | 10:14 AM
  #573
evil03's Avatar
Originally Posted by Ladogaboy
No spacers. Just +48 offset.
I was going to go to albert originally, but he is pretty far from me. I'm lucky that I have Tony in my area.
The next project is have my tires rotated and get my alignment. I'm thinking -2 camber. That, and I need to remove the unnecessary spacer on my mudflap.
you can do that... my camber specs are above.... its the tires that are FAT....
at 255/40-18 its fatter, wider and taller then the stock setup
Old Apr 19, 2011 | 10:26 AM
  #574
robyn402's Avatar
gunna assume you had to pull the fenders more then just an average roll?
Old Apr 19, 2011 | 11:43 AM
  #575
Slyy's Avatar
Just a teaser pic until the weather gets better.
18x9 +30 Rota G-force
245 40 18
Eibach Pro Kit
Fenders were rolled and Pulled in all corners.
Thanks EVIL03 and billyboy1 for helping me out with the rims and tire spec
Old Apr 19, 2011 | 07:10 PM
  #576
Ladogaboy's Avatar
The difference in OD from stock is within reason: 12 revs per mile. Don't get me wrong: I don't need to adjust the camber in order for them to fit. They fit just fine stock. They would rub if lowered or if the car bottoms out.
I just want to adjust the camber while I'm getting an alignment, rotating the tires, and making sure the toe is 0.
Old Apr 21, 2011 | 08:55 AM
  #577
chris350dx's Avatar
ok quick question for you guys, i want 235/40/18 with 8 inch rim and plan on getting the swift springs, will i need to roll any fenders with this setup? if so then can i get away by switching to 225? also any idea of how much the swift springs lower you?
Old Apr 21, 2011 | 09:01 AM
  #578
BravoZero's Avatar
If you run any tire other than the stock 215 width and you're lowered, it's almost positive that you'll rub the inner fender at some point especially for daily driving. The Swift springs lower the car about an inch. I'd go for it and get them rolled. The fronts will be fine unless you're about two inches lower.
Old Apr 21, 2011 | 10:13 AM
  #579
evil03's Avatar
yup pull about 13mm
Old Apr 21, 2011 | 10:17 AM
  #580
evil03's Avatar
well first off there will be no rear camber adjustment.... you will need to get the white line rear camber kit to do so...
now depend on how you drive and how does your alignment...
imma running... .3 toe in the front and .3 toe in the rear.... if i remember correctly...
something about help me corner better lol... i dont remember... i have a track alignment guy do it for me
Old Apr 21, 2011 | 10:26 AM
  #581
evil03's Avatar
chris...
it will depend on you wheel spec! offset is the key....
form the 1st post...
18x8 +40 will = fronts will be flushed and rears will need a 10mm spacer being maxed flushed
Inner Clearance: 7mm LESS Outer Face Position: 19mm MORE
Tries: 235/40 18 no rubbing issues with stock height
18x8 +45 will = fronts will be closer to being flushed and rears will need a 10mm spacer to be maxed flushed
Inner Clearance: 12mm LESS Outer Face Position: 14mm MORE
Tires: 235/40 18 no rubbing issues with stock height
***FIT PERFECT with out SPACER***
Proof
https://www.evolutionm.net/forums/2009-la...s-tires-3.html
My track wheels
as you can see no rubbing.... no rolling.... but.... it also depend on the wheel makers.... some say there +40 offset but really there are like +38 which its 2 mm differ.... which will make a big differ with wider tires...
so roll it just to be save and not have to deal with noodling a tire
bravo..
+1 on this part "it's almost positive that you'll rub the inner fender at some point especially for daily driving. The Swift springs lower the car about an inch. I'd go for it and get them rolled."
now for ... "The fronts will be fine unless you're about two inches lower"
i am drop about 3.8 inchs in the front... and i still have my stock liner... lol... the front will eat up everything i throw at it... i fits 18x10 +25 no problem with 225/40-18 .. with a drop of 3.8 inches.... ... its the rear that is a *****
so anything lower then 4 inchs then you should start to worry about rubbing and cutting the tire
Old Apr 21, 2011 | 10:27 AM
  #582
evil03's Avatar
245 40 18
Eibach Pro Kit
sick! imma link your post to the 1st post....
Old Apr 21, 2011 | 10:41 AM
  #583
BravoZero's Avatar
Ah, thank you for the correction. I assumed that the fronts would need it as well, good to know!
Old Apr 21, 2011 | 10:52 AM
  #584
evil03's Avatar
updated!
Old Apr 21, 2011 | 10:53 AM
  #585
evil03's Avatar
imma her to help! nopro man
