AEM EMS Get tuning help for your AEM EMS system.
How many Knock Volts is consider bad for the engine?
Old Dec 3, 2004 | 09:51 AM
4Gsixty3's Avatar
m i detonating? i m seeing 2.7V of knock on knock Volt in my AEM EMS is that normal? this was done by 4th gear pull from 80-115mph. thanks in advance.
ps: i have it log on my pc if anyone needs to see it. thanks again
Old Dec 3, 2004 | 12:04 PM
4Gsixty3's Avatar
anyone?
Old Dec 3, 2004 | 12:38 PM
DSMotorsport's Avatar
I would need to see the log file, but 2.7volt is pretty good knock spike IMHO, definatly not engine noise. I back down the timing if I see knock voltage jumping up above significantly over the line.
if you want to email me the file sales@diamondstarmotorsport.com, Id be glad to look it over and offer whatever help I can.
Old Dec 3, 2004 | 03:00 PM
bs's Avatar
bs
Sounds like det to me as well. When everything is going well I only see like .3V of noise popping up every so often. If I saw 2.7V I would think it is knock.
Old Dec 3, 2004 | 08:16 PM
STFU Tuning's Avatar
It really depends on the car. On a stock motor EVO I would say you are knocking. I have logged some noisy built motors where 2.7 wouldn't be knock. I don't think this is the case though. Some cars are louder than others. Check the noise curve and look for spikes.
Also, when you log, do so with the knock control turned on and pulling timing above your set voltage limit. Sometimes the logger will not pick up and display a noise spike, but it will always display pulled timing.
I'll allow a max of 2.5 volts after 6400rpm on my car.
Old Dec 3, 2004 | 11:18 PM
4Gsixty3's Avatar
thanks for the help guys, love the evom community... can get so much help here.
mrm95
Jul 29, 2015 05:06 PM
R/TErnie
Oct 7, 2009 11:33 AM
steelcityevo8
AEM EMS
17
Jan 31, 2007 09:22 AM
KOEvo
Aug 25, 2006 02:02 PM
racegate
AEM EMS
Jul 17, 2005 01:35 PM
