AEM EMS Get tuning help for your AEM EMS system.
price range for AEM EMS?
Old Dec 21, 2004 | 04:52 PM
blackedout's Avatar
hey guys, im actually kind of new to the site, and barely go on it. i was wondering around how much is it to get this? i dont have much on the car, but i would like to get this piece for the future? can anyone help me out? any help is appreiciated. thanks in advance...
Old Dec 21, 2004 | 05:01 PM
IEXCELR8's Avatar
If you are not planning to upgrade your Turbo Then I would go with a flash, check out Turbo Trix. If so then I would go with the aem-roughly $2000-$2100 installed and tuned TT can also give you a price on this that is accurate. Busher can also. There are many threads on the AEM and you should do some reading about the intricasy (sp) of the AEM. It has tons of features. Again if no turbo upgrade use the money on other mods and you can still get close if not 4oo hp on the stock turbo. Determine your end goals and get on a pathway to achieve it.
My 2 cents!
Another site to look at is aempower.com-
Old Dec 21, 2004 | 05:06 PM
blackedout's Avatar
thanks!
Old Dec 22, 2004 | 08:21 AM
Jason Siebels's Avatar
If you want to make best power, regardless of what other mods you have done to your car, complete engine control is the best solution. The AEM is the easiest to install, and has an excellent network of users for the EVO. Not to mention some excellent tuners to help you out. I would definately purchase from the guy you want to tune the car, this will net you the best money spent as well.
jason.
Old Feb 13, 2005 | 05:37 PM
pyrovice's Avatar
so is a little over 2 grand the consensus for everything you need with the AEM ems?
Old Mar 12, 2005 | 02:20 PM
David Buschur's Avatar
We sell the complete system for $2400. What this gets you is this:
AEM EMS ECU, with the integrated wide band
5 bar map sensor
Billet map sensor adapter for the EVO
Air intake temp sensor
stainless steel bung for temp sensor
Wide band 02 sensor and bung
Pigtails for wiring the map and temp sensors
The car COMPLETELY tuned.
David Buschur
www.buschurracing.com
Old Mar 23, 2005 | 12:57 AM
cary's Avatar
5 bar map sensor
David Buschur
if we come to you and have it tuned say, in the summer, does it need to be retuned for the winter? what im asking is, assuming no more mods are added, is one tune sufficient for year round driving?
Old Mar 23, 2005 | 01:33 AM
KIDBANGA10's Avatar
Old Mar 23, 2005 | 09:27 PM
1.8t's Avatar
Wouldn't the IAT sensor correct for this?
Old Mar 24, 2005 | 12:44 PM
If I tune it in the summer and you don't add anymore mods then the tune itself will not have to be changed. You may have to add more start up fuel in the winter which is easy to do, but it should be fine.
David Buschur
Old Mar 24, 2005 | 01:19 PM
my04rs's Avatar
David Buschur
So then this system is not like the utec? With the utec in my sti I had to tune for for the summer and winter. If I tried to use my summer tune in the winter it would cause a lot of knock. In essence I am looking for a set it and forget unless I add more mods. For my needs I was going to do a reflash but if the aem does not need to be adjusted (or minor adjustments) I may go with the aem system.
Old Mar 24, 2005 | 02:53 PM
No, nothing like the UTEC. The AEM has air temp, water temp and you can even factor in pucker fact if you want and trim the fuel
David Buschur
Old Mar 24, 2005 | 03:02 PM
my04rs's Avatar
thanks for the info (and sorry for the hijack)
Old Mar 26, 2005 | 07:33 AM
omarboy25's Avatar
i picked mine up but for a lancer non evo
for $1400
Old Apr 9, 2005 | 04:30 AM
Precision Dyno's Avatar
You will get that with almost every piggyback system. The AEM is superior to any other EMS on the market. It controls every aspect of the air/fuel and ignition system completely. If you keep you Karmen with the system then little tuning if any will be needed if you add a few mods. If you convert to speed density then a retune of VE and ignition will be required for certain throttle ranges.
Look out for some nasty EVO's comming from philly this summer.
Jovan Caro
Feb 10, 2017 03:18 PM
codeman1892
Lancer Engine Tech
Sep 9, 2011 10:39 PM
Evoluvin
15
Oct 28, 2010 08:35 AM
5LEEPERISAH23I
Jul 19, 2009 11:00 PM
evoego
Dec 8, 2003 03:15 PM
