New AEM Serial Guage!
New AEM Serial Gauge!
Have any of you guys looked at the new AEM Serial Gauge? This thing is a must if you have an AEM EMS! It allows you to monitor 19 channels that the EMS looks at with warnings for each channel (fully user programmable through laptop sofware provided). You no longer need to go through the hassle to hook up the laptop to monitor a couple of things. THere are also 2 switched outputs that you can connect to a warning light if your gauge is in a spot that is a bit out of view! You can prioritize the warnings by make them primary or secondary. For example if you want to be warned that your a/f ratio is too lean for the conditions your running (I.E. boost and rpm) you might give that a #1 priority, but engine temp might be a #2 priority. I put 4 of these things in my Pantera, replacing the factory gauges! That's right, you can daisy chain up to 19 of these things together if you want. I use each guage to monitor things like coolant temp, oil pressure, fuel level, and boost pressure. Each gauge also monitors 4 other things that are set to take priority if they exceed any normal operating limits! So while my coolant gauge is interesting to look at, if I get a lean a/f under certain conditions, it jumps to override my coolant display and warns me with indicating a/f! Think of the benifits! 19 Gauges with warnings for the price of one gauge! Cool stuff. It's a standard 52mm gauge, with page up and down buttons on the front. It comes with 2 bezels (BLack and Silver) as well as changable faces (Black and White)!
This is especially nice for the EVO guys who have the U boxs with built in Uego's. Now you can add an A/F gauge...only it does much more.
Got mine via UPS just a few minutes ago...I can't wait to get this put in. I'm going to monitor IATemps, air/fuel ratio via wideband, and coolant temps from this gauge. SWEEEEEEET!
Chris
Chris
201Motorsports
Evo 'For Sale' Electronics / Lighting / Audio
77
Apr 30, 2010 06:05 PM
201Motorsports
EvoX 'For Sale' Electronics / Lighting / Audio
18
Nov 19, 2009 03:35 PM
EmeryatSTM
11
Nov 28, 2008 08:42 AM
evo8rcr
57
Nov 26, 2007 12:48 PM
