AEM EMS Get tuning help for your AEM EMS system.
Guys with AEM EMS....which intake with MAF del
Old Mar 11, 2006 | 11:52 AM
althemean's Avatar
I just had my AEM EMS installed and I have a generic intake that my tuner had laying around.....a pipe that was the right diameter for the stock intake tube connected to a cone filter.
What I want to know is what intake are you guys running with the MAF delete?
Old Mar 11, 2006 | 11:59 AM
Blue Evo 8's Avatar
you can use any cone style intake on a custom adaptor the same diameter as the intake tube..see my pics below and copy it ...
The HKS SSQ BOV is well hidden underneath the intake...
Old Mar 11, 2006 | 12:04 PM
althemean's Avatar
I know that, I already am just using an intake that fits. Just want to know what others are using.
Old Mar 11, 2006 | 12:05 PM
nothere's Avatar
I ended up using a used K&N, seeing as how they are so badly rated on the stock ecu. Then went with a ITG filter on the end of that.
the k&n is a pretty red color, looks sort of cam cover color.
Old Mar 11, 2006 | 12:07 PM
althemean's Avatar
must have added the pics while I was typing. I want to leave the stock box bracket in place like you did too. When it was off my IC pipes were chaffing on the radiator fan shroud.
Did you use a peice of pvc or something....I guess aluminum tubing would work as well.
Old Mar 11, 2006 | 12:18 PM
Blue Evo 8's Avatar
Piece of 3" diameter aluminum tubing....I'll take more pics when I get home.
Old Mar 11, 2006 | 02:15 PM
itzwolf's Avatar
I added a 4" elbow pipe to my HKS RS Intake, with a 4" coupler for the filter. Works like a charm.
Old Mar 11, 2006 | 03:55 PM
althemean's Avatar
You dont have to take anymore pics man. Appreciate the info. 3" diameter tubing and a cone filter with a 3" diam. inlet.
Vibrant performance should have the tubing and couplers.
Old Mar 11, 2006 | 04:50 PM
Blue Evo 8's Avatar
Old Mar 11, 2006 | 08:55 PM
platinumspecv's Avatar
just use a filter you dont need any pipes
mitdrx
Aug 4, 2018 07:06 AM
Dross99_si
Mar 4, 2016 08:27 PM
[Cyanide]
15
Jun 3, 2009 12:09 PM
reggiEVO
10
Oct 6, 2008 08:50 AM
PsychDr. HN$
Aug 21, 2008 04:51 PM
