AEM EMS Get tuning help for your AEM EMS system.
gas tank level reads low w/aem ecu?
Old Aug 2, 2006 | 04:41 PM
Aby@MIL.SPEC's Avatar
ever since i installed my aem, when my gas gauge reads empty i still 2 gallons left in the tank? I can only put in 11 gallons when the gauge is on "E".
is there a fuel level gauge calibration somewhere in the cal file?
i searched the 200 + page .pdf & I didnt find anything.
Old Aug 2, 2006 | 04:44 PM
nutrulz's Avatar
There is a specific pin that needs to be removed because it interferes with the Gas Tank signal.
I think its 74, search the AEM forums, I know it's there.
Old Aug 2, 2006 | 05:04 PM
turboDan's Avatar
Aby,check your post in AEM Forums as I provided a link for your answer and yes,^^^^^^^
is correct as pin #74 needs to be removed for ecm connector as it is an output for EGT #1
hope this helps you out.
Old Aug 3, 2006 | 11:40 AM
Thanks guys
now what's the trick for removing the pin from the yellow connector?
i searched under pin removal, but didnt get any results.
Old Aug 3, 2006 | 11:46 AM
EVOlutionary's Avatar
That's great info. My car has been doing this for a year ever since I got the EMS. Didn't worry me too much so I never messed with trying to figure it out. Sometimes I have about 4 gallons left when it hits the empty mark. I've gotten pretty good at estimating when it is almost empty. I've put 13.8 gallons in before, and have never run out of gas yet!
EVOlutionary
Old Aug 3, 2006 | 01:43 PM
turboDan's Avatar
Pulling the pin out is the easy part,finding out about this "flaw" was the problem.
Unplug connector,unlock pins by prying up on white lock(entire length of connector),it only pulls up about 1/16",then stick a pin in hole just under pin and push on pin in then pull gently on wire and it will come unlocked and pull right out.Hope this helps.If any problems,just call me,you know my number(hint: traded t-bodys on the exit off of i-5 by disney )
Old Aug 3, 2006 | 01:48 PM
Spaceball 1's Avatar
Hey thanks i always knew there was something alittle different with my fuel gauge since i put in the AEM. I kinda figured i was just getting worse MPG but could never put more than 10 gallons on E
Old Aug 3, 2006 | 04:31 PM
jbrown's Avatar
haha, I bought mine with an EGT sensor at the same time, so I never connected that wire ... good to know, thanks guys!
tsitalon1
19
Nov 5, 2010 12:38 PM
Fourdoor
Dec 28, 2006 06:53 AM
Chris@nolimitmotors
21
Jan 24, 2006 10:03 AM
Peazoo
17
Jul 10, 2003 10:53 AM
