AEM EMS Get tuning help for your AEM EMS system.
to AEM please help and frinds
Old Aug 16, 2006 | 06:04 PM
EVO-6.5 (KSA)'s Avatar
i have been hearing a lot of good stuf about AEM after sales service and that poshed me to go for it i had the choice of an HKS Vpro for a cheeper price thure my authrised dealer bu i sayd no i will stick with AEM and at that
time the car had a Power FC Lgetro
naw for my resideng problem that i have at the momint and i need your help badly
i have just boudht a new AEM 1313 EMS for my evo 6 and i am trying to get to work can you help me
thanks
note i have posted this thred on more than one forum
Old Aug 17, 2006 | 06:00 AM
GTVEVO's Avatar
thanks
Have you posted on AEMPower.com? They have a specific electronics form that they will probably respond much faster on.
Old Aug 17, 2006 | 08:56 AM
jbrown's Avatar
Sorry man, I have zero idea where to even begin on an Evo 6.
Old Aug 17, 2006 | 06:40 PM
i have
http://forum.aempower.com/forum/index.php?topic=17653.0
and guss what ? no answer
Old Aug 17, 2006 | 07:11 PM
GTVEVO's Avatar
Really sorry about that, it was just a suggestion. You might try to contact them directly and see if they can answer your questions.
Old Aug 18, 2006 | 09:49 AM
jbrown's Avatar
Yeah, every time I have contacted them on the phone, they have been very helpful.
But just as speculation, if the wiring harnesses are identical, I don't see any reason why it wouldn't be plug and play affair. I am unsure of how the ACD or AYC would work, though I don't even know if they had any of that in the 6.5.
Old Aug 18, 2006 | 10:39 AM
GTVEVO's Avatar
The only thing I have heard of being different is the fuel pump setup but I don't know this of being a fact or not just might be somthing you pay special attention too. I found this out when recieving a PowerFC for an evo7 it had some differences as well and could not be ran on an evo8, I would think similar issues would apply.
Old Aug 18, 2006 | 05:40 PM
i hace a power FC on my car for a while and i needrd to do the same for the pump but on the AEM it is defrint the cam sensor is not reading any thing and i cant get it to start or for the laptop to read any thing ???
please help
thanks
Old Aug 18, 2006 | 06:48 PM
Bump
Old Aug 20, 2006 | 03:52 PM
bump 2
Old Aug 20, 2006 | 04:07 PM
Bimmubishi's Avatar
Sometimes changing to a different cable and or laptop will solve the problem. Another issue could be a non matching software versions. I had a lot of problems similar to that with my Nissan SR20det EMS.
Old Aug 21, 2006 | 01:58 AM
thanks for the help
cable and laptop are the same that did 5 other AEM's .
help stil needed
Old Aug 21, 2006 | 10:07 AM
jbrown's Avatar
If the cam sesnsor isn't reading, check the ECU pinout diagram on the Evo 8 and make sure the sensor is on the same 2 pins. If it is, then either the polarity is reversed or it may work differently on the 6.5 and you may need to get a sensor from an 8.
Old Aug 21, 2006 | 04:58 PM
thanks for the reply
whin ever we plug all the conectors on the AEM it shows an eror but whin we unplug the conector number 3 ( con 61 ) tis error apeers
what cabels should i swap or change can you help out ?
this might help
http://www.lancerevoclub.com/piedinaturaecu-e.htm
alexis21
Feb 22, 2016 05:20 PM
jansoft_16
Apr 22, 2015 08:23 PM
6466evo
AEM EMS
Sep 1, 2014 01:03 PM
Wickedwhite8
AEM EMS
Apr 4, 2013 11:14 AM
EVOMIZ
AEM EMS
May 29, 2006 10:21 PM
