AEM EMS Get tuning help for your AEM EMS system.
knock volts when to worry?
Old Jan 30, 2007 | 08:12 PM
94AWDcoupe's Avatar
Originally Posted by brobards
Log the knock voltage on a pull with conservative ignition timing, this will give you an idea of the standard "noise" of the engine. Then I would use the standard noise as a baseline curve for your knock sensor cal table (setup->sensors->knock sensor->knock control), and turn your knock control on.
You can then begin to increase your timing and log the knock feedback, if you are experiencing any feedback this means that you are probably too aggresive for pump gas and should pull timing out at that point.
ditto
Old Jan 30, 2007 | 08:14 PM
94AWDcoupe's Avatar
Originally Posted by steelcityevo8
another question ? the knock that i am getting only shows up after a shift to next gear and as boost starts to build, i get it around 12-16psi not always the same boost level but i had seen it as low as 12psi and as high as 16 psi. just in 1 spot i might get 3.5v my threshold is at 2.5v. but once boost gets past that point i get virtually zero knock all 2.5 and under. if i do a log of say 3rd gear starting at 2500 rpm wot pull all the way out i never get this knock voltage at all ! only happens after shift in a very small window and is then gone once spoolup is full
If the spike responds to timing changes then it is real knock. If it doesnt respond then it is phathom knock.
Old Jan 31, 2007 | 09:22 AM
tabio42's Avatar
Also in case you didn't know - when you really start logging for knock, use the internal logger. The PC logger can't sample fast enough to pick up some spikes. I had a problem with that but the guys at AEM set me straight
There is a quick fix to using the PC logger though. If you have your knock threshold and retart settings set properly and you log Knock#1 Retard, it will tell you approximately when the computer reads knock above your threshold by showing you when it starts to retard timing.
jjayp
Mar 12, 2011 12:01 AM
acamus
Oct 24, 2008 06:22 AM
krillin
Feb 6, 2007 10:01 AM
spoolinspyder
AEM EMS
26
Mar 12, 2006 05:15 PM
racegate
AEM EMS
Jul 17, 2005 01:35 PM
