AEM EMS Get tuning help for your AEM EMS system.
Dash Outputs
Old Jan 4, 2007 | 04:16 PM
DarksideEng's Avatar
Dash Outputs
Hey guys, right now I have my meth spray light wired into my CEL light. When my nitrous maps kick on, my CEL light comes on (as per GTVEVO's instructions). Im wondering what other lights I have available on my dash and what are there corresponding output names. Mabye we could get a list going. I would like to mess around and see if I can have some other dash lights come on. Possibly a knock light? Shift light? I also have an '05 so I dont have an IC spray light (I dont think).
Ill start:
(Year) Dash Light - Output in AEM
-(05) Check Engine Light- LS10
Old Jan 5, 2007 | 03:52 PM
Any help?
Old Jan 5, 2007 | 04:45 PM
Spaceball 1's Avatar
I have no idea but im in the same boat as you. I want every light possible for shift lights. Have you tried the IC sprayer the light still might be in the cluster even thought 05 dont have the sprayer
Old Jan 6, 2007 | 06:09 PM
GTVEVO, where ya at? I bet he knows
Old Jan 8, 2007 | 02:49 PM
Anyone know if the 05+'s still have the IC spray light?
Old Jan 9, 2007 | 07:01 AM
kcevo's Avatar
Not sure if that pin out is still available or even if the dash has the light on the 05, but it's pin 35 and it's Injector #10 output on the '03. Hope this helps.
Old Jan 9, 2007 | 01:14 PM
Thanks for the help. Ill go see if I have it.
Old Jan 10, 2007 | 08:22 AM
GTVEVO's Avatar
Ya guys sorry the 05s don't have a dash IC Spray light because there was no IC Sprayer from the factory to my knowledge. I am sure you could still wire up your own light and push it with the same output or a new output that is unused. Then you could use your CEL light as a shift light or wire another light to that output also. This should work out very easily, the only obstacle I can think of would be to test the voltage on the output before purchasing a light to make sure you are buying for the correct voltage or use an open ground switch to activate it connected to a 12 volt source.
I haven't gotten in to doing this since I have been supplied with the extra dash IC Spray light on my 03 use by the alky injection now but hopefully this will give you an idea on how to get it accomplished.
Old Jan 10, 2007 | 04:06 PM
Is there a way to wire up a LED to come on when the knock voltages exceed 3volts?
Old Jan 10, 2007 | 08:42 PM
GTVEVO's Avatar
Yes, you could do this using the analog input if you aren't using it for the alky injection. Otherwise you would need to setup some sort output to switch on if there is one open. I have never done this but I have read similar ways of it being discussed and done.
Old Jan 11, 2007 | 03:15 PM
jbrown's Avatar
Anyone have a breakdown of all the dash lights and their corresponding pinouts?
Old Jan 11, 2007 | 05:19 PM
GTVEVO's Avatar
I believe the only two lights controlled by the EMS are the CEL and IC Spray light, I don't think anything else is dependant on it.
Old Jan 12, 2007 | 02:46 PM
jbrown's Avatar
Damn, those are the only two I knew of. I wish there were more, hell it doesn't even control the speedo!
Old Jan 12, 2007 | 03:14 PM
GTVEVO's Avatar
No but neither does any other car so you really can't expect it too. Standalone sensors provide feedback for most of the items. Just add your own lights and intergrate them into somthing to make it look custom.
mikegutt
Mar 5, 2012 01:26 PM
rish197
Jul 25, 2008 09:23 PM
Pure Playaer
Jan 3, 2008 09:17 PM
RA42925
14
Jun 2, 2007 07:24 AM
