AEM EMS Get tuning help for your AEM EMS system.
How do I view logged boost and AFR?
Old Feb 14, 2007 | 04:44 PM
dsevo's Avatar
I cannot figure out how to view AFR's and Boost when viewing my internal logs. The O2#1 displays, but the #'s don't correspond with my serial gauge (they range from like 8 to 3). I'm sure it's just some setting, but it's kind of annoying. Any help would be appreciated.
Old Feb 14, 2007 | 06:15 PM
truevo's Avatar
Your AFR range sounds like it not setup for gasoline, if that's what you are using. So, go to configure, select units in dropdown and then correct fuel for AFR.
Old Feb 14, 2007 | 06:51 PM
dsevo's Avatar
^ I checked that, but they were already on the right settings. Thanks for the idea though.
Old Feb 16, 2007 | 03:16 PM
truevo's Avatar
sounds like you will have to setup scaling in the graph for you voltage to AFR. Go to Setup, Sensors, oxygen sensor, 02 sensor#1, 02 sensor#1 cal table and then to graph. then setup your graph values in there.
Old Feb 16, 2007 | 10:56 PM
dsevo's Avatar
I figured it out. As you said it was not set on the right calibrations. I thought just changing the settings would allow me to look at previously downloaded logs, but I had to pull new ones from the ECU for the new settings to take place. Thanks a lot for your input.
mrm95
11
Sep 7, 2015 06:40 PM
kwboost
May 12, 2014 06:29 PM
jameswwt
Sep 3, 2012 07:19 AM
duck13
20
Sep 4, 2010 04:47 AM
Icem@n
Feb 11, 2010 11:34 AM
