AEM EMS Get tuning help for your AEM EMS system.
CEL as a Knock light
Old Apr 30, 2007 | 11:37 AM
johnjonfenomeno's Avatar
Just wanting to know .. can the AEM be configured to do this .. use your CEL as a knock indicator.. Please advise with directions.
Thanks
Old Apr 30, 2007 | 11:39 AM
evoteddy111's Avatar
+1 on a IX!!!! i know my friend with the old bug eyed WRX had it!!! but he wasnt on AEM
Old May 1, 2007 | 08:00 PM
Ackerson's Avatar
It's been a while since I did this but I'm pretty sure this is how you do it. Somebody correct me if this isn't accurate.
Using AEMPRO press Control-O, find LS10 ALTSWT. Set the value to ON.
Find LS10 SWITCH, set the value to SWITCH #7 ON.
GO to SWITCH #7 ANALOG IN, set the value to KNOCK #1.
Move down the SWITCH #7 ON ABOVE, and set that value to whatever voltage your knock retard table starts pulling timing.
I don't know if this would work on a IX.
Old May 2, 2007 | 06:29 AM
crap .. Im already using programmable switch #7 as a map switch and boost switch... But yah that is pretty accurate
Old May 23, 2007 | 09:10 PM
SLO-EVO's Avatar
wow great post... i have been looking for this
Old May 26, 2007 | 12:55 PM
16g-95gsx's Avatar
This doesn't really work though, since the knock signal threshold is not a constant value. You will have it trigger too early or too late depending on where you define your switch #7 threshold.
