AEM EMS Get tuning help for your AEM EMS system.
question about buying EMS
Old May 22, 2007 | 12:26 PM
dafunk630's Avatar
hey guys,
this might sound like a stupid question but what kind of sensors do i need to buy when i buy my EMS for my IX to make it work at its fullest???
-thanks
Old May 22, 2007 | 12:27 PM
Blue Evo 8's Avatar
Originally Posted by dafunk630
hey guys,
-thanks
air intake temp
MAP sensor
wide band
EGT
Old May 22, 2007 | 12:33 PM
dafunk630's Avatar
THANKS!!! also what comes with the kit when u buy it???
Old May 22, 2007 | 12:36 PM
Spaceball 1's Avatar
nothing, unless you get a set up from like buschur or other rep shops.
Old May 22, 2007 | 12:37 PM
A few shops also give a decent tune set-up for your car when you purchase the EMS from them.
Old May 22, 2007 | 12:39 PM
dafunk630's Avatar
what is the difference between 3.5 bar map sensor and the 5 bar map sensor???
Old May 22, 2007 | 12:45 PM
ryan0's Avatar
1.5 bar.
if i recall...
3.5 measures a 50 psi range. -14 to +35
5.0 measures a 72 psi range. -14 to +56
3.5 is plenty.
Old May 23, 2007 | 08:18 PM
SLO-EVO's Avatar
Originally Posted by Blue Evo 8
air intake temp
MAP sensor
wide band
EGT
EGT is optional.. you dont really need it if youre running a wideband..
to my knowledge (not bashing you in any way shape or form just IMO)... i am not running EGT with my EMS...
Old May 23, 2007 | 08:24 PM
Blue Evo 8's Avatar
no problem.....I need to get a wideband asap....
Old May 24, 2007 | 11:43 PM
ninja808's Avatar
The pricing on these has drastically dropped in the last few months, I went ahead and opted for the 1313U w/Built in wideband. It's a good investment if you're planning to do your own adjustments in the future.
Old May 25, 2007 | 09:03 AM
Aby@MIL.SPEC's Avatar
here is how i would rank the sensors in importance
1. map sensor w/rre or buschur map sensor block to mount to intake manifold
2. wideband
3. ait
a distant 4th: egt
do yourself a favor if you get the aem ems, buy the map sensor mounting block to put the map sensor as close to the intake as possible. if you dont, you have a pressure transport delay to the sensor by running any length of line. trust me, i have measured this & posted somewhere illustratin the transient boost delay associated with line length.
this transport delay can & will induce knock.
Old May 26, 2007 | 12:48 PM
16g-95gsx's Avatar
I can also vouche for the sensor delay time of placing a map sensor in various locations. The further you get from the ports, the more damped the signal is, but the more laggy it becomes.
Old May 28, 2007 | 10:55 PM
Jolly Roger's Avatar
What if you already had a wide band like Innovate/Zeitronix would you still need the AEM wide band sensor for the EMS , Also EMS does data logging so EMS + A/F gauge you wouldn't need an Innovate/Zeitronix right????
Old Jun 3, 2007 | 06:21 PM
0100's Avatar
Veteran: Army
I would like to know also.
Trying to decide between 1320 with Zeitronix or 1320u...
Old Jun 3, 2007 | 10:27 PM
SwiftEVO's Avatar
No you can just wire them into the ems. I have the innovate and I just used one of the analog outs to the factory front o2 pin. And then just configured the ems for the right volts.
--Josh
