AEM EMS Get tuning help for your AEM EMS system.
couple questions about EMS!!!
Old Sep 26, 2007 | 12:05 PM
dafunk630's Avatar
hey guys,
i finally got my 37r in the car and tuned!!! but i got a couple questions. IDK since its a IX if its different but my cold start is pretty bad. when i turn the car on at idle the rpm goes up to 1500rpm and goes down to about 300 or 400 rpm than it goes back up to 1500 rpm. i just wonderin how can i fix that problem??? another thing is that when i am cruising at low rpm like 2000 the seems to bog any ideas???
-thanks
Old Sep 26, 2007 | 11:10 PM
sekula's Avatar
well i don't think you're supposed to cruise at 200 rpm lol...that might fix your problem
Old Sep 26, 2007 | 11:54 PM
Evo_Pma's Avatar
+1
the other problem maybe u can fix it in the idle table , let me know if can help u with that
Old Sep 27, 2007 | 02:46 PM
App420's Avatar
xx tuning
Old Sep 27, 2007 | 03:30 PM
gsxwingz's Avatar
Did the tuner adjust the Warm Up Enrichment table? Your idle is swing around hunting for a decent A/F ratio. Start it up, open the table, and up/down your fuel depending your a/f ratio.
Your other problem, is AEM tuned using conventional, o2 fb, automapping, or boost comp? I think I know your problem but need more info.
Hope this helps.
Old Sep 28, 2007 | 08:52 AM
alpha's Avatar
The Idle% probably needs to be brought up a little bit for cold start. And your RPM Offset vs Start table could go longer (seconds, not rpm)
Old Oct 10, 2007 | 05:11 AM
gr8evo's Avatar
Post up the map and I will give it a look
dsmtalontsi95
Aug 25, 2018 05:44 AM
AirBez
Sep 27, 2016 11:19 AM
secretagentstv
Jun 1, 2015 11:29 PM
MicRX
Jul 29, 2009 05:19 PM
morfhious3
11
Jul 13, 2009 10:46 AM
