AEM EMS Get tuning help for your AEM EMS system.
How much knock (V) is actually knock?
Old Dec 2, 2007 | 11:56 AM
mandy1's Avatar
HKS 272,stock turbo evo8 and exedy twin disc.i set the knock cal table 2v over 3000rpm. how are your settings?
Old Dec 2, 2007 | 03:11 PM
GTVEVO's Avatar
You really should set your own calibration, please read over at aempower.com on how to do this. It is not hard at all, just take your time and continue to listen and check plugs as you test to be absolutely sure no knock is present in your tune. The base cal file with the AEM will usually get you started and in the end you will probably end up with a high setting around 2 or 2.5 volts at 7k tapering down to around .5 volts or so before spool. Good luck
FYI if you have knock you will see a spike above your normal noise trend in your logs.
Old Dec 8, 2007 | 11:05 AM
EVO Tweeker's Avatar
The car should be run through all RPM ranges under WOT load without boost and logged for base knock.
That base knock should be your knock cal table. Anything above that base knock on boost in that RPM is actual knock.
Atleast that is how I understand it.
stunt2
Aug 18, 2011 08:53 AM
Bugermass
70
Apr 30, 2010 11:02 PM
Inprogress
Aug 4, 2008 10:52 AM
steelcityevo8
AEM EMS
17
Jan 31, 2007 09:22 AM
jmoudry
20
Dec 31, 2006 08:01 AM
