AEM EMS Get tuning help for your AEM EMS system.
Yet Another Hard Start Thread
Old Dec 19, 2007 | 02:04 PM
dsevo's Avatar
Originally Posted by DTM
I sent you an email
Just responded, but I used a different email, because my other one wasn't working. Thanks.
Old Dec 20, 2007 | 06:58 AM
alpha's Avatar
Send me your calibration with details on the injectors, intake manifold, cams, map sensor, etc. Will see what I can help you with from here
alpha at brotherzracing.com
Old Dec 20, 2007 | 11:31 AM
dsevo's Avatar
sent. Thanks.
Old Dec 30, 2007 | 09:45 AM
11secEVO7's Avatar
Can't believe people are still having this problem..
on my last evo it would take about 5-6 seconds to start and I had to touch the gas pedal as well...
5-6secs is a long a$$ time imo..
I may actually leave the AEM this time and go Autronic
Old Dec 30, 2007 | 10:28 AM
GTVEVO's Avatar
I promise you its the tune that is your problem, there is alot of adjustments to be made to provide the best startup. Not just the normal trim tables but park adjustments and correction factors and your base tune must be stable also since it acts as the primary base fueling varible. If anything is changed you must factor in changes for all other tables otherwise it will then again be incorrect.
Old Dec 30, 2007 | 11:08 AM
Evoovasti's Avatar
try doing it in 20 degree new york weather it takes forever to start
Old Feb 4, 2008 | 08:17 AM
awdboosted's Avatar
I work with autronic.. It's just as bad with cold starts.
Old Feb 5, 2008 | 11:27 AM
DSMu4ia's Avatar
I had this problem with several tuners as well until I found someone who really knew what they were doing.
Now the car starts the same in 20degree weather as it does in 80degree weather.
The tuner that got me figured out was Brad Brooks.
Also, to get rid of the sync time that causes slow starts with the AEM, look here:
www.triggerdisc.com
Old Feb 6, 2008 | 10:05 AM
awdboosted's Avatar
Thats great and all for DSM but It doesn't look like it works for an EVO yet. You can limit the crank time by spending time tuning the car better and getting rid of sync timing. It will never start like a stock ECU.
Old Feb 6, 2008 | 01:45 PM
tony gibson's Avatar
Originally Posted by dsevo
Mine makes no noticeable difference whether it is cold or warm. It might even start slightly better in cold weather.
wow...wish mine started as good in the cold....10 degree weather ftl! Takes two ten second cranks to start when cold....and that is with tinkering with the crank injector time table, start decay table and rpm vs start offset.
Old Mar 7, 2008 | 08:23 AM
tabio42's Avatar
what do the park adjustments do?
I had mine starting in 4 cranks or less until I started screwing around with those. Now i can't get it to go back
Old Mar 11, 2008 | 10:43 PM
dsevo's Avatar
This gentleman was kind enough to look at my maps, but unfortunately when the changes were made to improve starting, the rest of my maps were changed and the car was running lean at wot. This concerend me so I just put the maps back the way they were and left them.
I actually went back and soldered all of my wires for my AIT sensor and the MAP sensor because they were only connected with those crimp connectors, and it actually seems to start faster. Maybe its just the placebo effect. Anyways, I guess 3-4 cranks isn't all that bad. I've come to realize that an EMS is never going to start like a stock ECM.
Old Mar 12, 2008 | 09:58 AM
ExViTermini's Avatar
a lot of people complain about the crank time on the EMS. One thing you need to be sure and do is wait for the fuel pump to finish priming before you crank the car. Also, as stated many times, its not gonna start like a stock ecu.
My car it seems random, sometimes it will hit after 1 crank, sometimes it takes 6.
Old Mar 13, 2008 | 11:48 PM
dsevo's Avatar
This is exactly what mine does. Sometimes like stock, others not so much, and no rhyme or reason why.
Old Mar 14, 2008 | 10:26 PM
Aby@MIL.SPEC's Avatar
+1
