AEM EMS Get tuning help for your AEM EMS system.
Yet Another Hard Start Thread
Old Dec 13, 2007 | 09:05 AM
dsevo's Avatar
I've had my car running with EMS for quite a while now, and have always put up with the hard start issues, but now I've decided to try to figure it out. Would any of you experts in EMS starting mind taking a look at my .cal file to look for anything that can be improved? I have made all of the changes mentioned in the EMS section already.
BTW, my car isn't horrible like some people's 5 minute start times, it just takes like6-8 cranks sometimes. More annoying than serious.
Old Dec 13, 2007 | 11:40 AM
brodienuchies's Avatar
It's good to just turn the key on and wait a few seconds while the fuel pump kicks in. Have you tried this trick yet?
Old Dec 13, 2007 | 11:53 AM
GTVEVO's Avatar
One thing to check is the Idle Park Target, this should be set around your cold startup rpm % value to help with an easier non stumbling startup. If it is too high or too low it can help result in stumbling hard start or overly high rpm start.
It it takes 6-8 cranks it also might be your crank injector time being too lean. More time % is needed to get that burst of fuel to help fire up.
Old Dec 14, 2007 | 08:07 PM
dsevo's Avatar
Yep, I wait until the fuel pump is done priming every time. Thanks.
Old Dec 14, 2007 | 08:09 PM
dsevo's Avatar
Thanks, I'll take a look at this. I don't really have a stumbling issue, however the crank injector time thing souds feasible. Where do I find the crank injector time setting, and what should it be approximately? Thanks.
Old Dec 14, 2007 | 09:46 PM
MZP@TeamD's Avatar
Former Vendor
What size injectors are you runing?
Old Dec 14, 2007 | 11:46 PM
dsevo's Avatar
AMS 780cc. Thanks.
Old Dec 15, 2007 | 06:56 AM
alpha's Avatar
Just keep reading. Sounds as simple as your crank injector time table
http://forum.aempower.com/forum/inde...c,17194.0.html
Old Dec 15, 2007 | 07:13 AM
juice_evo_VII's Avatar
Even at best I've found I'm still cranking for 20 ish seconds until it syncs.
Old Dec 15, 2007 | 07:21 AM
evo_08's Avatar
my car cranks for about 5 to 8 sec. and i thought mine was bad.
Old Dec 15, 2007 | 07:40 AM
I'd like to get it down to that but during the cold months, ain't happening.
Old Dec 16, 2007 | 02:08 AM
dsevo's Avatar
Mine makes no noticeable difference whether it is cold or warm. It might even start slightly better in cold weather.
Old Dec 16, 2007 | 01:44 PM
awdboosted's Avatar
Read my post.. This should help.
https://www.evolutionm.net/forums/sh...=305992&page=2
Old Dec 19, 2007 | 10:05 AM
dsevo's Avatar
Originally Posted by awdboosted
I copied your three graphs you showed in that thread as closely as I could, and the car seems to start slightly worse. I'll keep playing with it and let you guys know if something makes a drastic improvement.
Old Dec 19, 2007 | 10:08 AM
DTM's Avatar
DTM
I sent you an email
