AEM EMS Get tuning help for your AEM EMS system.
wb 02 sensor placement
Old Jan 13, 2008 | 05:22 PM
dsmjeffro's Avatar
im getting ready to install aem ems do i need to get another bund welded in my dp or can i just replace the factory o2 sensor with the wideband one ?? seen some cars with it some say go some say no what would you guys do ?
Old Jan 13, 2008 | 06:42 PM
lemmonhead's Avatar
no you leave the factory one alone. have the bung welded at a 1:00 position about 36inches down from the exhast manifold.
Old Jan 13, 2008 | 06:47 PM
GTVEVO's Avatar
I have done it both ways the sensors seem to last longer in the o2 dump than in the down pipe either way you should be fine.
Old Jan 14, 2008 | 08:46 AM
dsmjeffro's Avatar
What If I Add Race Gas To The Mix ?
Old Jan 14, 2008 | 10:21 AM
lemmonhead's Avatar
race gas will shorten its life, anything to rich will shorten it.
Old Jan 14, 2008 | 11:01 AM
GTVEVO's Avatar
Race gas will indeed shorten the life of the sensor but some tips to help preserve the life helps. Such as be sure to let the sensor warm up before starting the car and it does seem to help if the sensor is up in the front O2 position to keep it hot. Now as you know you don't want it too hot but with my sensor in the front O2 position I have had better luck when running race fuel. Just something to think about.
Old Jan 14, 2008 | 11:39 AM
dsmjeffro's Avatar
Thanks For All Your Input Guys Ill Give It A Try Up Front It Like 5 Inches From The Turbo But It Might Work Well I Plan On Mostly Running Pump Gas Then Some C-12 When I Take Her To The Track I Also Would Like To See A 11.7 To 11.5 Afr With Aem Lucky If I Drive The Car 5k A Year So It Should Last Me A While
Old Jan 14, 2008 | 02:47 PM
jason900rr's Avatar
i have mine in the 2nd o2 sensor bung and im running meth and i only get apx 4-6 months out of my sensor
Old Jan 14, 2008 | 02:51 PM
dsmjeffro's Avatar
strange maybe meth is bad for it ? dunno though
Old Jan 16, 2008 | 11:51 AM
05graphiteMR's Avatar
it has to be close enough to keep it hot and not allow the gases to cool and colect on the sensor.... if your running rich that will shorten the life alot as well. shouldn't matter race fuel or not as long as its tuned well
Old Jan 16, 2008 | 11:54 AM
dsmjeffro's Avatar
acually getting alex from dogbox to tune my car on ems
so the orginal location should be good?
with a good tune of course
Old Jan 17, 2008 | 08:40 AM
i would think so
Old Jan 17, 2008 | 01:15 PM
dsmjeffro's Avatar
Ill Give It A Shot If Not !? Oh Well Lesson Learned.......
Old Jan 25, 2008 | 09:00 AM
SwiftEVO's Avatar
I took my front o2 out and put my wideband in its spot. About 2-3 inches from the turbo outlet. Readings are wayyy better. The response to throttle inputs are just perfect.
--Josh
Old Jan 29, 2008 | 09:46 AM
dsmjeffro's Avatar
Thats What Alex @ Dog Box Is Doing Cant Wait To Get My Car Back
