AEM EMS Get tuning help for your AEM EMS system.
Help Connecting To Ems!!!
Old Feb 26, 2008 | 05:24 PM
dafunk630's Avatar
hey guys,
i am trying to connect my laptop to the ems by aem pro v1.0.
So i connect it to my laptop and open aem pro then i get a pop up sayin "connect to ecu or work offline" i get the option connect or work offline. then i hit on the button that says connect. Then it says "Failure connecting to ecu"how do i go about connecting it??? pleasse help me out guys!!
-thanks
ps. i am using a usb to serial port cable
Old Feb 26, 2008 | 05:33 PM
ericblackevo8's Avatar
Before you try to connect you need to have your car completely off.
Old Feb 26, 2008 | 05:40 PM
dafunk630's Avatar
i tried doin that!!
Old Feb 26, 2008 | 05:43 PM
ok, with the key all the way in the off position. Hit connect ecu and then turn the key to just the accesories it should connect. Did you try that.
Old Feb 26, 2008 | 05:46 PM
dafunk630's Avatar
yes
Old Feb 26, 2008 | 05:48 PM
hmmm? let me go try my car to make sure i am giving you the correct procedure.
Old Feb 26, 2008 | 05:50 PM
dafunk630's Avatar
k thanks
IEXCELR8's Avatar
http://forum.aempower.com/forum/inde...c,11403.0.html
Old Feb 26, 2008 | 05:52 PM
2k4EvoVIII's Avatar
make sure the com port is setup right for your usb converter and whats in aem.
Old Feb 26, 2008 | 05:53 PM
dafunk630's Avatar
how can i go about that??
Old Feb 26, 2008 | 06:06 PM
2k4EvoVIII's Avatar
In Windows XP following these directions
1)Right Click My Computer
2)Go to Properties
3)Click on Hardware Tab
4)Click on Device Manager
5)Click on the + sign next to Ports
6)Look for your USB Adaptor and remember what COM Port it says.
7)Open AEM Pro 1.0
8)Click Work Offline
9)Click ECU on the Top
10)Click on Communication Port
11)If USB is already selected and its not working click on Serial and in the Drop Down make sure that the right COM port is selected.
12)Click on the Connect Button in AEMPRO or hit Shift F7
Chris
IEXCELR8's Avatar
Sounds like you are having problems with your USB to Seral device. The USB to Serial adaptors made by IO Gear are the ones typically recommended. In windows XP look under your device manager to make sure that the usb device is working and you have a seral port for it listed. USB to Seral adaperts are known to cause issues.It could also be the driver for the cable.
Old Feb 26, 2008 | 06:07 PM
With the key in off position pull up aem pro.When the box comes up asking to connect hit connect and while its querrying turn your key to the on position. This should connect you. This should work if not their must be some sort of other problem.
Old Feb 26, 2008 | 06:12 PM
dafunk630's Avatar
k i will try that
Old Feb 26, 2008 | 06:31 PM
Any luck?
