AEM EMS Get tuning help for your AEM EMS system.
Idle control not working
Old Sep 17, 2008 | 11:23 AM
Rushin's Avatar
Car idles erratically, RPM is moving from 1300 to 1700 back and forth. Modifying the Idle% vs Target RPM table has no effect. Tried all zero and idle feedback still goes to minimum value trying to lower the RPMs.
I got the 1313 unit on an 03 evo. Using the base MAP calibration. I've adjusted the TPS sensor, checked all others - AIT, MAP, Coolant, 02.
TPS is below 'Idle off' threshold, RPS are within limits of idle. Tried the options to Reset Idle motor at kef off and on. No luck...
I need some help here. Thanks in advance
Old Sep 17, 2008 | 11:57 AM
BBrooks's Avatar
Did you check this....
If you are having Idle control issues on Mitsubishi, check and MAKE SURE that you have the following options set to ON
Idle 1/2 Stepper
Idle 3/4 Stepper
These options can be found under the Options full list menu.
I am seeing several calibrations with these turned off, the idle circuit will not work with these options turned off.
Old Sep 17, 2008 | 02:17 PM
Rushin's Avatar
I checked the options and they are ON. Thanks for the advice.
Should I try to go back to the stock ECU to make sure its not a bad stepper motor? It did work just a few days ago though...
Old Sep 19, 2008 | 12:35 PM
Spaceball 1's Avatar
email me your cali i can check it.
