AEM EMS Get tuning help for your AEM EMS system.
ems vs wideband a/f
Old Sep 29, 2008 | 06:40 PM
czilla's Avatar
ems vs wideband a/f
my ems show 8.4 to 8.6 a/f and my wideband shows 14.0 to 15.0 why would that happen?
Old Sep 29, 2008 | 06:45 PM
travster's Avatar
you have to configure the aem to us standards
Old Sep 29, 2008 | 07:01 PM
czilla's Avatar
how do u do that
im new at all this aem ****
i used to have a rsx with a krpo its very different
Old Sep 30, 2008 | 09:05 AM
Spaceball 1's Avatar
configure, units, select the afr gasoline.
Old Sep 30, 2008 | 10:45 AM
czilla's Avatar
did that still i think its a bad ground
Old Oct 1, 2008 | 08:59 AM
loppad's Avatar
Did you check your "O2 #1 gain"? For AEM Gauge or similar the value is 1 or similar, but for other you need to calibrated it using that gain.
Old Oct 1, 2008 | 09:31 AM
czilla's Avatar
the gain is at 0 now do i just go in the setting and change it to 1 or so
Old Oct 1, 2008 | 09:45 AM
alpha's Avatar
Configure -> Units -> AFR Units CLICK AFR GASOLINE -> CLICK APPLY -> CLICK OK
If it still doesn't display you don't have the white wire from the gauge wired to O2 #1. Even if AFR Gasoline is selected it defaults to CLICK on AFR Gasoline CLICK on Apply CLICK on OK
Old Oct 1, 2008 | 10:39 AM
loppad's Avatar
What alpha says is right: most EVO's maps are set in Methanol so you have readings in 4, 5 usually 6.5 which means 14.7 in gasoline. Do what he says first.
Otherwise, If you see that AFR changes (goes down which means is making the mix richer) as you press the fuel pedal then goes back to 8 and stays then your gain has bad offset.
The manual says you have to take the O2 sensor out to calibrate it but I did this and also worked:
Having the car hot and idle move the O2 gain up till matches your wideband gauge values.
BUT you have to be very sure that your wideband sensor and gauge are accurate and wired propperly otherwise you might get too lean and will hurt your engine because you're changing your scale from 8 to 14 so thats leaning the hole fuel system.
loppad
Old Oct 29, 2008 | 01:45 PM
blacksaleen95's Avatar
Where's the WB02 grounding at? I've found on the aem cars I've worked on (non-evo) with similar problems it's a grounding issue. Grounding @ the same spot as the ecu is best...Some of the guys with rear mount battery even have to run a full length ground from - side of the battery to the ecu/ems ground. The ems/gauge should be within .2 from eachother max, if it's more even after you've adjusted your gain, you most likely have a ground issue.
