AEM EMS Get tuning help for your AEM EMS system.
boost control map
Old Oct 1, 2008 | 05:45 PM
mandy1's Avatar
boost control map
anyone with a good boost controller map and settings on feedback,etc for a gt35r and gm solenoid?
Old Oct 29, 2008 | 02:00 PM
blacksaleen95's Avatar
there's a couple threads on the aem forums about setting up boost control.
http://forum.aempower.com/forum/inde...pic,994.0.html
also a word doc off the forums
http://eclipse.erichmoraga.com/AEM/I...st_control.doc
I've found the gm solenoid can be a pita sometimes and if the max duty cycle (85.xx%) is too high it'll stick. If your soleniod makes a buzzing noise at idle or key on you can change the base wg map at your lowest rpm point to get it to stop
good luck
