AEM EMS Get tuning help for your AEM EMS system.
fuel cut load with 3.5map
Old Oct 19, 2008 | 06:44 AM
mandy1's Avatar
any idea how to set this for no load fuel cut?max settings is 35.12 i want to run 36-38 psi but dont want to use a 5bar map since it dont have a 4 bar option.in other ecus i have run 44psi with a 3bar map with a lot of success for years, just tweaking with the 30psi range in the fuel cells.i know is not the best option but works for me. Any idea?
Old Oct 19, 2008 | 08:00 AM
veta's Avatar
If you use 3,5BAR sensor it means you have 3,5BAR absolute, so it is aprox 2,5BAR relative to athmospherical preasure. And 2,5BAR is aprox 35-36PSI. So you cant set Boost Cut to something higher, because you would be out of scale.
Old Oct 19, 2008 | 01:57 PM
GTVEVO's Avatar
Depending upon what aem version you are running I believe you can turn it off by setting it to -14.69
Old Oct 19, 2008 | 08:35 PM
mandy1's Avatar
version 1.19.i understand all the maps stuff,just want to turn off the load fuel cut in case it have some spikes or i decide to run a few more pounds using the old school way. will try your suggestion Gtvevo.
Old Oct 23, 2008 | 12:19 PM
veta's Avatar
Sorry, but how do you want run off-scale ? How should your ecu know how much fuel or ign you need in this case ?
Dont do something stupid, 5BAR map is not so expensive
sebas-chan
Apr 25, 2018 06:03 AM
peisden
Apr 12, 2015 03:29 AM
lancerMXV6
Aug 20, 2013 08:06 PM
LeveeciusEVOIX
Aug 19, 2012 08:50 AM
blackevolution8
AEM EMS
May 21, 2009 03:45 AM
