AEM EMS Get tuning help for your AEM EMS system.
FullBlown/Double pumper wiring question
Old Dec 28, 2008 | 06:37 PM
dryad001's Avatar
Im assuming both of these can be wired the same. I opted to go with the Fullblown unit and have a few questions.
Instead of using a hobbs switch I would much rather have the AEM trigger the 2nd pump. I found the diagram below but Im having a hard time trying to figure out what output (pinout) on the AEM I can use or what would be suitable to use.
Any help would be greatly appreciated.
Old Dec 28, 2008 | 07:11 PM
mandy1's Avatar
Wink
im using LS5 output.
Old Dec 29, 2008 | 04:56 PM
MZP@TeamD's Avatar
Former Vendor
Your wiring is right,use pin 51 (LS3)on ems then go to option ,configure outputs turn on the basic activation and function and you are set.
good luck.
Old Dec 30, 2008 | 02:47 PM
dryad001's Avatar
Thank you very much
Old Dec 31, 2008 | 09:25 AM
joeracer321's Avatar
I just run both pumps at the same time, it makes wiring simple, and takes a failure mode out of the equation. I do not have a fuel pressure problem or rich afr using this method.
liass44
Jan 3, 2017 09:20 PM
Howulikemyevo
Dec 3, 2013 03:15 PM
ToxicFab
12
Sep 17, 2012 07:24 AM
hokiruu
Sep 29, 2007 11:32 AM
FullBlown
20
Jan 17, 2007 09:00 PM
