AEM EMS Get tuning help for your AEM EMS system.
Look at this log
Old Jan 18, 2009 | 01:07 PM
czilla's Avatar
Look at this log
i think i have and issue with my a/f if someone with some aem knowlege look at this and tell me if my o2 sensor went bad or wtf.
File Type: zip
Old Jan 18, 2009 | 03:10 PM
czilla's Avatar
nothing?
Old Jan 19, 2009 | 11:11 AM
chuckbyu's Avatar
There is def a problem with the O2 sensor. A/F won't stay that steady at idle much less driving. I would first check to see if something came unplugged. Or unplug your O2 sensor and see if the AEM sees 14.7 (just like you would if you were calibrating it). Other than that my only suggestion would be replace the O2.
Old Jan 19, 2009 | 03:43 PM
czilla's Avatar
yea i think its the o2 sensor b/c my uego is also reading 14.8
i ordered a new sensor i should recieve it by friday i check then
thanx
Old Jan 23, 2009 | 08:03 AM
DynoDude55's Avatar
It may have come unplugged or check all of your wiring and make sure you have no exposed wires as well. If your using race gas that will also kill a wideband O2 sensor much quicker that reg gas.
Old Jan 23, 2009 | 12:16 PM
czilla's Avatar
i got the new sensor and it seems to be ok but we will see how long this sensor will last
and i only use 93 sunoco gas.
Old Jan 27, 2009 | 02:57 AM
Spicy's Avatar
Well you said it's working now with the new sensor so i guess it was not unplugged. Where do you have the sensor mounted? If it is to close to your turbo you will keep burning them out.
Old Jan 27, 2009 | 06:42 PM
muffner's Avatar
any news?
Old Jan 28, 2009 | 08:30 AM
czilla's Avatar
yea it was the wideband sensor installed it yesterday and everyting is ok
i hope it dosent happen to often the sensors arent to expensive ($70) but i dont want to have to replace it every 2 months.
its on the downpipe right before the high flow
