AEM EMS Get tuning help for your AEM EMS system.
AEM timing #s Vs ECU Flash timing #s?
Old May 20, 2009 | 01:56 PM
Colt4g63's Avatar
How do these compare?? As in 12 degrees advance in ECU flash = what in AEM??
Old May 20, 2009 | 06:44 PM
awddyno's Avatar
They should be the same.
Old May 20, 2009 | 06:48 PM
06RedRalli's Avatar
Aem timing is the exact value ecu is estimated.
So aem is exactly what u set it to and will fire at whatever value you put in.
Old May 21, 2009 | 02:01 AM
Colt4g63's Avatar
This is not what I have been told by a few other shops..... But I have yet have my real question answered by them as well.....
Old May 22, 2009 | 07:27 AM
EVO8_PR's Avatar
What have you been told?
Old May 22, 2009 | 02:23 PM
awdboosted's Avatar
I think the timing can vary between stock ECU vs. AEM EMS. I would start with much lower number timing numbers, start to add timing until you see knock, and then back off. That’s what I would do. But I don't think the value will be the same.
Old May 22, 2009 | 02:36 PM
JohnBradley's Avatar
The value doesnt vary that much from ECUflash to AEM. Even if it does a little its only a few tenths. We have put lights on both and verified the timing via AEM and EvoScan. The main thing is having to think in terms other than load (ECUflash) and in either KPa or Psi with the AEM. With the advent of SD on the stock ECU it makes it even easier to compare what the timing numbers need to be versus an actual pressure value.
For instance, Lucas' car on the stock computer and the AEM are very very similar in the timing map at a given boost value. Our Head fabricator TJ's 61mm stock ECU/speed density map is very close to what I see in AEM cars.
Old May 22, 2009 | 02:38 PM
We have also compared DSMlink and AEM and you really can compare numbers with that and see that they dont vary much.
Old May 23, 2009 | 09:44 AM
Colt4g63's Avatar
How much lower on the timing in AEM over my ECU Flash timing map do u think is safe to run on the AEM?? You think i can go 1 degrees less everywhere and be safe?? Thanks for some clarity BTW!
Brorena
Aug 6, 2013 06:50 PM
Rumblefish237
Jul 10, 2011 07:29 AM
turbodreamz21
Apr 12, 2009 09:37 AM
Freddy302
Nov 7, 2007 09:14 PM
saleen281
Sep 8, 2007 01:31 PM
