35R cars and timing maps?
You could call up AMS and ask them the same, and they would say come in and get a tune..... nothing is free. Tuning fees are so expesnive (relatively) to say mechanical work because you are paying for the tuners experience. Anybody can put numbers in cells, the speed and accuracy with which you get to those numbers is what you pay for.
Scorke
Ok i knew i would get the captain obvious comments.. I understand what your saying more then you obviously know.. lol. But thats ok i understand how it is.. you never know who your talking to on forums, so understood. I was simply trying to start a thread where people could share there info such as they do with ECU Flash... I didnt know that was so bad??
I hear your sentiment, unfortunately the people that can shell out 1400 dollars for a standalone can usually pay for a tune, where as lots of people can afford ecuflash cables and not a tune.
It isn't "bad" to ask for help just stating that you wont find many self tuned standalone users out there.
Scorke
Scorke
Yea everyone has the "i dont wanna help anyone out unless i get paid" attitude. My car is tuned and makes over 500AWHP on pump on AEM so im not looking to copy anyones maps etc.. I have timing #s and i would be glad to help someone else out. I was making this thread to see what others were running compared to myself and get a good thread going to help others which would benifit everyone IMO.. Im also trying to figure out how the timing correlates with ECU flash compared to AEM as i personally have found the timing numbers to be quit a bit lower then ECU Flash. English Racing seems to be the only shop out there that gives a crap about there customers and even people like me who havent spent a dime there "yet that is
" and are willing to help and talk with me over the phone etc. I know where my business will go from now on.
Pretty sad when it becomes like this IMO.
" and are willing to help and talk with me over the phone etc. I know where my business will go from now on. Pretty sad when it becomes like this IMO.
I wouldn't post a timing map simply because people who shouldn't be tuning their cars are... and when they mess up and blow their engine up... they're going to blame the people who supplied the map regardless of any waivers.
Summary of thread... if you can't tune your own ignition advance tables, you shouldn't be "t00ning" your car.
*** 1991 GALANT VR4 ***
This is what I am using. 2.0/GT37r/1000cc
8.5:1cr
HKS 272
My Current Tune at 34psi 11.5afr 12 degrees of timing makes about 530awhp on Q16. I would guess that at 34psi I should be in the low 600hp rage, so I still need to pull out a lot of fuel and add a ton of timing to the car.
I figured I would share because I am self tuning the car, and I know how hard it is to find info. None of the pro tuners want to let you know the trade secrets which I respect. So here is the info I am using to tune my car. If anyone here thinks this info is bad or needs to be adjusted please let me know. I also post up CALs and Logs on the AEM Forums.
This is specific to Built Motors.
Pump Gas (91oct Cali)
AFR: 11.0-11.3
Timing: 10 degrees before spoolup, 15 degrees at Redline
Boost: 25-28psi
Knock: Less than 2.5 volts
Q16 or C16
*** Q16 requires 4-6% more fuel over your C16 tune ***
Q16 or C16 - Low Boost
AFR: 12.5
Timing: 22-25 degrees
Boost: 30psi or less
Knock: Less than 3.0 volts
Q16 or C16 - Medium Boost
AFR: 12.5
Timing: 18-22 degrees
Boost: 30-35psi
Knock: Less than 2.7 volts
Q16 or C16 - High Boost
AFR: 12.5
Timing: 12-18 degrees
Boost: 30-45psi
*** The reason for less volts on knock with more boost is, when knock happens at 45psi, stuff breaks quicker, so put in some extra buffer. You can remove all of that buffer but these are the guidelines that I am using.
http://forum.aempower.com/forum/inde...c,24045.0.html
CAL and Log File are on the second post.
8.5:1cr
HKS 272
AFR: 11.0-11.3
Boost: 25-28psi
Q16 or C16
AFR: 12.5
AFR: 12.5
Boost: 30-35psi
AFR: 12.5
Boost: 30-45psi
Last edited by TheBoz; May 27, 2009 at 09:36 AM. Reason: Made sure people knew what kind of car it was.
A 1G will take more timing advance then the EVO engine will. EVOs are known to accept lower timing advance then the 1G 4G63 DSM engines. I have a built 1G and from all the 1Gs ive tuned personally anyway, they accept more timing advance then the EVOs ive tuned. Probably due to being less efficient if i had to take a guess
i have a red on 91 octane / m2 cams / all bolt-ons....run @ your own risk...
my engine is very sensitive between 6500 & 7200 revs....or so the knock sensor claims....so that is why my map flattens out there.... the higher revs, the engine takes the timing.
I target ~27.5 on 91octane & get it by ~4100 in 3rd gear, evo8 5spd
rpm 26.5 28.1psi
3500 6.9 6.7
3900 6.5 6.3
4300 6.2 5.9
4700 6.5 5.9
5100 6.9 6.2
5500 7.3 6.9
5900 7.6 7.3
6300 7.9 7.6
6700 7.9 7.6
7100 8.3 7.9
7500 9.0 8.3
7900 10.1 9.0
8300 11.8 10.1
rpm 26.5 28.1psi
3500 6.9 6.7
3900 6.5 6.3
4300 6.2 5.9
4700 6.5 5.9
5100 6.9 6.2
5500 7.3 6.9
5900 7.6 7.3
6300 7.9 7.6
6700 7.9 7.6
7100 8.3 7.9
7500 9.0 8.3
7900 10.1 9.0
8300 11.8 10.1
I think you can use the maps, all will depend on how you use it..!!
If you don't have a base map, you can use another guy map who has your same mods, and start working from there.. If you see that it is too aggressive you can lower it, if it is too conservative, you can give it a try and adjust a little step at a time.
Just my opinion..!!
Just my opinion..!!
Id like to see what everyone is running on there 26-27ish PSI pump gas timing maps in AEM to get an idea.... OR even the guys that run 30psi and pump! Lets see the maps or give a round about answer at least. I know not every car will be the same.. Im looking for some data here to compare with ECU Flash timing figures that im so used to seeing.
Maybe some of the Buschur guys that run big boost on pump with there 35R sized turbos can shed some light. Or maybe even Dave will be nice and help some of us out with some info??
This is always going to be the biggest argumentative topic :lol. I don't get why others get so hurt about it, Colt4g63 is not asking for a complete map
, but maybe just tips on where he needs to start peak boost timing and go from there. Colt I don't have EMS until next year, I'm on ECUFLASH but here's my build:
2.0-JE 9.0 Crower
Manley Built head
SBR 35r kit
AFR: 12.5 on Sunoco 116
4-16 timing @ 28 lbs
4-14 @ 32 lbs
This is what I used to baseline, then started moving timing gradually till I got 1-2 knock counts, I won't go into detail on the final timing because each car will be different and at your own risk. Do lots of logs and you'll see how fast your 35r goes.
2.0-JE 9.0 Crower
Manley Built head
SBR 35r kit
4-14 @ 32 lbs
2.0-JE 9.0 Crower
Manley Built head
SBR 35r kit
4-14 @ 32 lbs
I was just trying to get a thread started in here to share information etc about the AEM in general really... The ECUFlash board is constantly hoppin and there is a wealth of information goin on there because of it.. I was just making an effort to make a thread like it over here. There needs to be more action and support in the AEM forum. This place is like a ghost town.
Mellon Racing
579
Jul 31, 2024 11:57 PM
rEVOlution04
Oct 14, 2010 03:41 PM
krillin
Feb 6, 2007 10:01 AM
