AEM EMS Get tuning help for your AEM EMS system.
Car dies when put in neutral while driving. HELP!
Old Feb 18, 2010 | 03:52 PM
EvoVIII :D's Avatar
While driving, when i put the car in neutral to stop at a light or something it wants to die. The idle usually goes to about 700rpm and then dies if i dont give it a little throttle. I figured it an idle issue, but not really sure of what to do. Any ideas would be great help.
The car also is fairly tricky to get going in first, you have to have it perfect or it will stall. Any ideas with that would be awesome too.
Everything is great other than those two things.
Thanks
Old Feb 18, 2010 | 04:02 PM
96eclipseGST's Avatar
What are you using to tune the car? Try logging and sending it to awdmotorsports see if something funked up
Old Feb 18, 2010 | 04:21 PM
EvoVIII :D's Avatar
I dont really want to tune it myself, but the idle is something i could work with on my own with my laptop. Im learning a little more everyday though
Old Feb 18, 2010 | 04:25 PM
Tribal's Avatar
check for leaks
josel_atr's Avatar
how did the tuner tune your car? did they send you a basemap and flashed it in your evo through tactrix cable? if yes, they might have given you a wrong basemap.
Old Feb 18, 2010 | 04:34 PM
EvoVIII :D's Avatar
Originally Posted by Tribal
check for leaks
I was going to check for vacuum leaks tonight actually
EvoVIII :D's Avatar
Im not sure, i left the car with AWDmotorsports and they did the work. The car runs great otherwise though
Old Feb 19, 2010 | 05:41 PM
EvoVIII :D's Avatar
ttt
Old Feb 22, 2010 | 01:27 PM
Aby@MIL.SPEC's Avatar
has it always had this issue or is it new?
this is an easy fix.
Old Feb 22, 2010 | 04:06 PM
EvoVIII :D's Avatar
It has always had this problem, I figured it was a slight tuning error. Its not bad if you know how to drive it. Let me know, would be greatly appreciated!
Old Mar 6, 2010 | 07:49 PM
UndergroundA's Avatar
I dont know the answer to your question but id love to hear what mite cause that idle to drop cause im experiencing the same problem slightly in my car with the AEM EMS
Old Mar 6, 2010 | 07:55 PM
Now the problem used to be a lot worse in my evo, then i called down to the shop that did the work and they had me locate a set screw somewhere under the hood and slightly turn it, he then had me drive it around.. It fixed the problem with the car shutting off at lights, but the idle still slightly fluctuates when I put in the clutch
Old Mar 6, 2010 | 08:08 PM
ray3328's Avatar
What screw?
Old Mar 7, 2010 | 02:22 PM
EvoVIII :D's Avatar
On the throttle body?
Old Mar 7, 2010 | 07:40 PM
prockish_03evo's Avatar
The screw he is referring to is the BIS screw which is located on the throttle body. You will probably need to tight the screw down to raise is slightly. If the screw turns and nothing happens you might need a new which is no big deal really i know of 3 evos on which the screw is stripped and they have never even been touched before, I hope this is helps keep us updated!
