AEM EMS Get tuning help for your AEM EMS system.
Idle issues
Old Apr 1, 2010 | 05:45 PM
davezorz's Avatar
Idle issues
So recently I purchased Bill's (Fookster) 2004 WW Evo RS. It has been running amazingly the past 2 weeks but I have noticed a new issue. It is tuned on the AEM EMS and was road tuned up in MN. Jordan over at MAP tuned it.
The past 3-4 days I have been having an odd issue; when the car idles it will rev up to 2,000 and stay there until I tap the gas and then it goes back to 1,200-1,500 and won't do it again for quite some time. I can't really tell what is causing it and I had a local tuner look at it, he said everything was fine in the map. Any ideas?
Old Apr 1, 2010 | 06:58 PM
cssaddictm4's Avatar
Sounds like the IAC might be sticking. This is what happens to me sometimes during start and warm up.
Old Apr 2, 2010 | 06:36 AM
awdboosted's Avatar
Make sure there is some slack in the throttle cable. There has to be slack in the cable. Also Check the TPS and make sure its under 3%
That’s the FIA or fast idle air and is use for cold starts. That’s why we have coolant that flows to the throttle body. When the coolant gets warm it shut the valve. This valve allows for more air during start up until the car gets warm. I don't that the IAC is sticking.
Old Apr 19, 2010 | 08:13 AM
Good info, for what its worth there are no coolant lines going to my TB, when I unplugged the IAC the idle issue stopped, I will check your info for my issue later.
Old May 15, 2010 | 08:06 AM
SkipDMan's Avatar
Correct your 'Idle FB under RPM'.
Old Jun 3, 2010 | 07:32 AM
davezorz's Avatar
I'm not sure if it was the 'Idle FB under RPM' or more slack in the cable but it is fixed now! Thanks, guys!
need_an_evo
Mar 29, 2016 09:14 AM
need_an_evo
Mar 28, 2016 02:21 PM
COBB Tuning
Cobb AccessPORT
95
Sep 24, 2015 07:35 PM
JordanS4
28
Oct 6, 2008 03:45 AM
Bigjoeski05
Lancer Engine Management / Tuning Forums
17
Oct 18, 2006 12:25 PM
