AEM EMS Get tuning help for your AEM EMS system.
Knock Sensor Settings
Old Apr 4, 2010 | 07:19 PM
VTEC Killer's Avatar
Can someone post their knock sensor settings. I am trying to get my car road ready again, I havent driven it in a few months and right now my knock table isnt setup. Im running so rich it doesnt matter I couldnt make this car knock if I tried, so I just want the settings so im ready when time comes to retune.
Old May 1, 2010 | 05:03 PM
almost a month with no reply
can anyone help me out with this?
Old May 2, 2010 | 10:18 PM
project_skyline's Avatar
I'll have one you can try, I will post it up tomorrow.
Old May 18, 2010 | 09:37 AM
Paul Walkin's Avatar
Why dont you do a pull logging knock how the car sits since you know it won't knock, then use the log to make a basic map of "normal/accepted" knock values?
Old May 19, 2010 | 03:39 PM
TheBoz's Avatar
Built motor here is what I run.
0.1171875 0.1171875 0.44921875 0.80078125 1.1328125 1.484375 1.81640625 2.1875 2.48046875 2.75390625 3.0859375 3.30078125 3.515625 2.5390625 1.7578125 0.99609375 0.99609375
Old May 19, 2010 | 05:21 PM
kreionic's Avatar
word Every motor is going to have different levels of noise. Someone elses knock cal is going to help much with yours
Old May 20, 2010 | 06:18 AM
Originally Posted by 0xDEAD
The AEM has proportional noise reaction. That in and of itself is useless and has nothing to do with a detonation pulse which needs DSP style processing to bring out of a piezoelectric sensor signal.
So what's this have to do with anything?
Also, if you have your knock cal to a max of say 2 volts, then you do a pull and record say 4 volts on the log of your knock, is it really 6 volts (4+2 accepted) or is it 4?
Old May 27, 2010 | 03:07 PM
Up for answers.
Old May 27, 2010 | 09:13 PM
TheBoz's Avatar
When you log your Knock log
Knock #1 Raw (un filtered)
Knock #1 Volts
I always log both values.
Old May 27, 2010 | 09:58 PM
I understand that much, but is the value displayed your total value or is it a subtracted value based on your knock map?
For example, if you log 4 volts of knock and your knock map makes 2v acceptable, do you really have 6v of knock or 4?
Old May 27, 2010 | 10:52 PM
TheBoz's Avatar
when you log the data it is the data. So 4v = 4v.
All the knock map does is tell the computer when to pull timing and add fuel based on your settings.
You knock map uses the knock #1 volts to decided what it needs to do.
So if you are at 5600rpm and your knock sensor cal table is at 3v, and when you are running your car and you see 4v @ 5600rpm, that means that you should use the Ign Control and Fuel Control tables to determine what do do.
So you just exceeded the cal by 1v, so you can look at your Knock Retard/Volt and that will tell you how many degrees of timing it will pull per 1v of knock that exceeds the Knock sensor cal table.
Same goes for the fuel control options.
Hope this helps.
Old May 28, 2010 | 09:28 AM
Great explanation, thank you.
Old May 28, 2010 | 02:10 PM
BillSpec's Avatar
Did you try out his knock sensor cal.?
Old May 31, 2010 | 06:40 PM
I havent yet, the car is leaking fluid, t-case is coming back out tomorrow.
Old May 31, 2010 | 08:12 PM
Where is it leaking from?
