AEM EMS Get tuning help for your AEM EMS system.
Exporting Logs to Virtual Dyno (not dyno room)
Old Sep 13, 2010 | 08:17 AM
Tbtalon94's Avatar
Alright having some issues here. I export the log like it says, re-name the values as need and import it into Virtual Dyno and i get an error saying:
input string not in correct format.
Anyone get this to work??
Old Sep 14, 2010 | 07:20 AM
browningderek's Avatar
i used a free program called open office calc. save log as text, open in open office, copy and paste in whatever program you like.
Old Sep 23, 2010 | 03:57 PM
BillSpec's Avatar
Its pretty simple,
While viewing your datalog in AEM log,
1. Highlight and zoom in where TPS is WOT only.
2. Click File, Export.
3. Export as text, click your parameters to be shown in VD: Normally Engine speed, Engine load, and 02 1.
4. On the bottom of the export window, select, current zoom area or w/e .
5.Send it to your desktop, then open it with virtual dyno.
Make sure you open the options menu in VD and select the data you want to be shown.
Next to boost you must type, Engine Load, to display manifold pressure.
Good luck.
Old Sep 24, 2010 | 08:55 AM
Tbtalon94's Avatar
I figured it out. I was doing everything right and it wasn't working.
My problem is I have a MAC and have Windows installed via Bootcamp. Well what happened was it doesn't set the langugage properties right and caused the program to not understand the input. Changing it back to English and everything worked properly!
Old Sep 24, 2010 | 11:04 AM
itzwolf's Avatar
Interesting... Glad you solved it.
EVOlution561
Jan 15, 2024 05:14 PM
Mweisel
Nov 5, 2015 12:24 PM
babaz7
Oct 1, 2011 11:08 PM
BillSpec
AEM EMS
28
May 25, 2011 04:01 PM
CMB
54
Dec 19, 2010 08:32 PM
