AEM EMS Get tuning help for your AEM EMS system.
Wideband output to AEM EMS
Old Nov 22, 2010 | 04:34 AM
VTEC Killer's Avatar
Hey guys I just installed an AEM Gauge-type UEGO wideband in my car. I wired it up correctly, I set it up correctly defining the sensor in the wizard in the aem software. My question is this..... When my gauge reads 14.2, my EMS is showing 13.9, so its about .3 lower than the gauge, this number seems fairly linear as when the gauge shows 13.2 the EMS shows 12.85 How do you sync them up so the gauge and ems read the same. I know its something to do with the gain setting, but am I setting the gain in the EMS or messing with the gauge? I checked over on the AEM forums but there is alot of mixed info and unanswered questions.
Old Nov 22, 2010 | 06:05 PM
kreionic's Avatar
Change the gain in options menu under o2 #1 or #2 depending on which o2 your using
Old Nov 23, 2010 | 11:59 AM
Is the gain going to be voltage based? If so, would it be best to measure the voltage coming in from the sensor at the gauge and then from the signal wire at the EMS and then add the difference in the gain? I would imagine you would do this with the engine off so the voltage would be somewhat stable. It seems too easy....lol
Old Nov 23, 2010 | 02:37 PM
kreionic's Avatar
Which Aem wideband do you have? If you have the one with the 2 plugs on the back of the gauge with engine off and ign on unplug the plug going to the sensor. Look at o2 #1 or #2 whatever your using. The gauge will read 14.7 or 14.8 change the gain so your Aem is reading what your gauge is.
Old Nov 23, 2010 | 02:46 PM
Thank you sir. Yes im using the 2 plug one, one plug is 4 wires power, ground, output and serial, the other goes to the sensor.
Old Dec 1, 2010 | 10:20 AM
rtype16's Avatar
Yep just unplug your sensor from the wiring harness car off with ignition on. Do this at the sensor connection. Than your gauge will usually read 14.7 than adjust your gain in the EMS to match and plug the sensor back in and you should be good to go.
maperformance
Evo 'For Sale' Electronics / Lighting / Audio
591
Mar 6, 2015 07:21 AM
Andrew@AMS
Automotosports - Illinois
Sep 18, 2012 07:01 AM
karwh0re89
Sep 13, 2012 08:37 PM
vinnieg
Dec 1, 2011 04:04 AM
rogue
15
Oct 31, 2009 11:27 PM
